RCU Forums
-   RC Tanks (https://www.rcuniverse.com/forum/rc-tanks-369/)
-   -   Under construction (https://www.rcuniverse.com/forum/rc-tanks-369/11624088-under-construction.html)
Darkearth74 11-28-2015 02:44 PM
Under construction
2 Attachment(s)
New build
Darkearth74 11-28-2015 05:32 PM
1 Attachment(s)
http://www.rcuniverse.com/forum/atta...mentid=2132944
philipat 11-28-2015 05:43 PM
Panther F?
Darkearth74 11-28-2015 06:25 PM
3 Attachment(s)
Panther 2http://www.rcuniverse.com/forum/atta...mentid=2132945http://www.rcuniverse.com/forum/atta...mentid=2132946http://www.rcuniverse.com/forum/atta...mentid=2132947
Darkearth74 11-28-2015 06:27 PM
3 Attachment(s)
http://www.rcuniverse.com/forum/atta...mentid=2132948http://www.rcuniverse.com/forum/atta...mentid=2132949http://www.rcuniverse.com/forum/atta...mentid=2132950
Darkearth74 11-29-2015 10:14 AM
1 Attachment(s)
http://www.rcuniverse.com/forum/atta...mentid=2133005
Darkearth74 11-29-2015 12:50 PM
1 Attachment(s)
Oh yeah this prolevel kit,lolhttp://www.rcuniverse.com/forum/atta...mentid=2133036
Darkearth74 11-29-2015 02:37 PM
1 Attachment(s)
http://www.rcuniverse.com/forum/atta...mentid=2133064Maybee i get the names wrong a liddle bit,but i can building at pro levels,yes
MAUS45 11-29-2015 02:53 PM
Nice build Darkearth74, it is definly Chris Ludwig's Panther F kit. It is good to see how easy his kits go together. Are you going to use Tamiya running gear?
Darkearth74 11-29-2015 03:57 PM
On christian ludwigs site de,it is listed as an panther 2 ,probley ill use an aftermarket board and tammy suspension and trans,very slow and precise is the way im gonna handle this build maybe a year will see its completion,some handfitting of components is required
MAUS45 11-29-2015 05:49 PM
Panther II, even better!!! Keep the pictures comming!:cool:
Darkearth74 11-29-2015 06:22 PM
1 Attachment(s)
http://www.rcuniverse.com/forum/atta...mentid=2133109This is how far i am currently,takes a long time to order parts from other countries,;-)
philipat 11-30-2015 09:31 AM
looking good. If you're doing a Panther II, then the running gear should be from a King Tiger, right?
MAUS45 11-30-2015 09:46 AM
1 Attachment(s)
It looks like the driver and radio operators hatches you have are for a Panther A. The Panther II hull has Panther G hatches. Check out this site for photos of the Panther II hull on display at the Patton Museum before it was moved to Fort Benning. I atteached one of the photos of the hatches as well.
http://www.peachmountain.com/5star/T...erII_Tank.aspx
Darkearth74 11-30-2015 04:42 PM
Yes philiphat,kt running gear,ill be using parts sprues from the kt ,jagdpanther ,and panther for external detail,as for the hatches ,muas45, i countacted chris late last night because you sparked my curiosity about the panther a hathes,the answer he gave me was very long and detailed and made perfect sense to me,i will try to to tell you as best as i can.the panther 2 that i am building was an very early design ,designed before the panther a actually went into production ,so certain apsects would be the same as the panther a ,such as the driver and radio operators hatches, I beilieve the panther 2 at fort knox was built when the panther g went into production,so by that time certain revisions had been made,so in affect that panther 2 is closer to a mid production,and the panther 2 that i am currently building would be the initial concept,wich when you think about it makes perfect sense .
sollie 12-01-2015 05:02 AM
following for sure
chris3BK 12-01-2015 06:20 AM
hi
I m happy to see this kit build here :-).
About the hatches, sure the one frankenstein hull in the museum shows something diverent. but is this a real panther II? no. or better not as it was desined during the Panther A/D produktion.
The real panther II hull should be a lidel longer and should have diverent armor angels as the Panther G and F models have.
the Panther II is diverent in a lot of point in compartaion to the G hulls.
it is somethin like the missin ling between the early panthers and the kintiger desin.
After the Ingernes calculatetd a down time of panther produktion of 6 month if the panther II had to start produced, the Panther II was canceled.
and as most as posible of the developing went into the G model and F.
so in developing order it was : Panther A/D .........Panther G, panther F
.................................................. .........Panther II
.................................................. ..........................Kingtiger
Also the turret of the panther II is longer as the developed F model
you can see the drawing compared in the pancer tracts books, there are realy nice drawings wer you cansee most diverence.
hope i could help a bit :-)
cu christian
Panther F 12-01-2015 07:58 AM
Nice to see one of these actually get built on the Internet.
We ALL know the Panther II that WAS at the Patton museum was the only known chassis/hull that survived the war. That turret and the driver & radio hatch area are from a G Panther... because NO Panther II turret (Schmale Blende) was ever constructed. Panther F turrets (Schmalturm) were built but that was not for the Panther II.
The Panther II hull hatches DID resemble those of earlier Panthers (A & D).
The Panther D was the first built... then the Ausf.A (Panther I's) and THEN the Panther II was to take place but was cancelled. The G series soon followed and then the F never (as far as we know) was assembled but hulls and turrets were constructed.
Jeff
Darkearth74 12-01-2015 10:47 AM
Thank you panther f,i didnt think we needed a supeflurous reineration of chris's explanation of production order ,but you did well in the recap,:cool:
Darkearth74 12-02-2015 10:08 AM
1 Attachment(s)
http://www.rcuniverse.com/forum/atta...mentid=2133567Yes the panther 2 hull is a bit longer than a panther g hull,if you look closely ,that becomes visable
Darkearth74 12-04-2015 06:59 PM
1 Attachment(s)
http://www.rcuniverse.com/forum/atta...mentid=2133972Suspension
Darkearth74 04-04-2016 06:01 PM
1 Attachment(s)
http://www.rcuniverse.com/forum/atta...mentid=2156023
MAUS45 04-05-2016 01:17 PM
Looks good Darkearth74!!! Are you going with the G turret instead?
philipat 04-07-2016 07:52 AM
Looking good! Where are you getting metal parts from (fan guards, hatches, etc)?
Darkearth74 04-07-2016 05:49 PM
Scratchbuilt the oil ,transmission covers,rear engine plate and periscopes,ordered parts from different sources ,thank you its difficult but im trying.Daniel
Darkearth74 04-07-2016 05:52 PM
Please delet this post attachment did not load
Darkearth74 04-16-2016 02:36 PM
1 Attachment(s)
http://www.rcuniverse.com/forum/atta...mentid=2157649
Darkearth74 04-17-2016 01:43 PM
1 Attachment(s)
http://www.rcuniverse.com/forum/atta...mentid=2157799
