Backyard runner
Looking for a backyard tank, something to run around my backyard. My 1/16th scale tanks get hung up in the grass and roots, so am looking for something with more clearance. It does not have to be a real tank, just something to run around the backyard and have fun, do not need battle ready.
So here is what I am looking for: Larger than 1/16th scale with ~2" ground clearance. Robust track system since I will be bouncing over things Does not matter f it is brushed or brushless Preferably a metal chassis and metal tracks, but not a deal breaker Also what controller/ESC do you recommend for a tracked vehicle. Thinking about something like this... but feel you guys will know about these things... rc chassis |
Whatever size and shape you decide on be sure it has enough oomph to pull your lawnmower. It is a lot easier to get hobby expenditures past the wife if they seem to accomplish something practical.
No wife, so no expenditure issue...
So I started to work on this again. First built a turret turning system. The goal was unlimited turning without wiring getting wound up.
Started with a geared down motor: 24v DC brushed worm gear motor, 15 rpm, 70kg.cm / 5.2 ft lbs. https://cimg6.ibsrv.net/gimg/www.rcu...643881497c.jpg The motor has a 8mm output shaft. I bought some 8mm steel shaft to extend it. Since I want unlimited rotation, I decided to go with a hollow slip ring. SInce I want to be able to expand on what is in the turret, I decided on a 12 wire version with 10 amp current. I plan on a paintball or airsoft gun in the turret, as well as other accessories (lights, camera...). here is the picture of the slip ring. https://cimg3.ibsrv.net/gimg/www.rcu...4ae25c772a.jpg The goal is a low profile system, so I chose the hollow slip ring with a 12.7mm hole, because it is easy to find 12.7mm (1/2") to 8mm sleeves. They are used to adapt US 1/2" routers to take 8mm bits. This way the hollow slip ring fits over the sleeve attaching the 2 8mm shafts. https://cimg2.ibsrv.net/gimg/www.rcu...aaa683d2b7.png So I welded the sleeves to the 8mm shaft I bought and mounted a Rigid flange with a 8mm hole. Flange and shaft https://cimg1.ibsrv.net/gimg/www.rcu...ca2b8db7fe.jpg Everything welded together, with drilled/tapped hole for a set screw. Flange is also attached by set screws. https://cimg6.ibsrv.net/gimg/www.rcu...7a2c1bfad0.jpg Shaft fitted on the motor https://cimg1.ibsrv.net/gimg/www.rcu...215fa5450f.jpg The complete assembly https://cimg6.ibsrv.net/gimg/www.rcu...163b42144b.jpg |
| All times are GMT -8. The time now is 04:21 PM. |
