RCU Forums
-   RC Tanks (https://www.rcuniverse.com/forum/rc-tanks-369/)
-   -   Matotoys "processing" (https://www.rcuniverse.com/forum/rc-tanks-369/4136726-matotoys-%22processing%22.html)
Shagnifico 04-07-2006 02:23 PM
I ordered two new smoke units from matotoys back on march 26th. When I check the status of that order on their website it says that the order is "processing", whatever the hell that means. I emailed matotoys a few days ago, so far all I have heard from them is the automated customer service email.
Is "processing" an evasism for "back ordered" ?
Evasism, I just created that word, It's mine, but feel free to use it.
jstrat121 04-07-2006 10:00 PM
RE: Matotoys "processing"
Shaggy!
that surprise me!!!
I have had nothing but good experiences,and fast e-mail replies from MATO.
Maybe he is on vacation or something?
Good luck!
Shagnifico 04-07-2006 10:11 PM
Oh nevermind. The email that I thought was the auto reply was a real email. Says they shipped my product on march 27.
I'm a tard.
Carry on.
jstrat121 04-07-2006 10:23 PM
He said, "TARD!":D:D:D:D:D
tomzag 04-07-2006 11:53 PM
what does "tard" mean? i look up in dictionary, no found.
Grain 04-08-2006 12:18 AM
ORIGINAL: tomzag
Found the answer for you in [link=http://en.wikipedia.org/wiki/Tard]Wikipedia[/link], today's new comprehensive information source.
tomzag 04-08-2006 12:41 AM
thank you, new ward for me!!
thanks,tom
mariodx3 04-08-2006 12:55 AM
1 Attachment(s)
shagnifico did you get your tank yet? I order my tank from toyeast and they shipped it out on march 27. And i got my tank april 5 with no damage to the box at all.
Grain 04-08-2006 09:05 AM
ORIGINAL: tomzag
thanks,tom
You're welcome. :)
If I'm ever stumped either Wikipedia or the Merriam Webster online dictionary has always been able to come to my rescue. I'd say if you can't find it on one of those sites, you probably don't need to know about it. ;)
Shagnifico 04-09-2006 03:45 PM
Ok now I got the smoke unit. How do I hook it up ?
I stuck the black wire from the tank into the black side of the plug, and the red wire from the tank into the red side of the plug. But it doesn't run.
jstrat121 04-09-2006 05:36 PM
Plugs into the two-pin connector on main (bigger) board,(only with S/S will it work)
Shagnifico 04-09-2006 10:34 PM
Ok, I did that. What else do I need to do to make it work?
Shagnifico 04-11-2006 04:55 AM
C'mon, nobody has replaced a smoke unit before?
Stang951 04-11-2006 05:10 AM
That's all you should have to do. It simply plugs into the bottom of the large receiver board. Add smoke oil and go. If it doesn't work check to make sure that the switch is in the on position. If it still doesn't work you could try using jumper wires and a spare battery to test the unit, just make sure to connect the correct wires. Coloring seems to make no difference in these tanks, as my white wires were positive and the red wires were negative.
If you know how, you may want to use a voltmeter to test if you are getting current to the unit itself.
Shagnifico 04-11-2006 07:28 AM
I tested the new units with a battery and they work. The old smoke motor would still run when I took it out of the tank, it just wouldn't smoke.
So between now and then something else has broken so that power will not even go to the smoke unit plug.
Thus ends my Hen Long experience, can't say it's been pleasant.
This tank will meet a violent end.
I have neither the time nor the inclination to continue trying to modify this tank into what I paid for.
Stang951 04-11-2006 04:58 PM
Don't kill it Shag. May need some oil in it. My new uints came without oil.
Sell it if you dont want it...unless you need some burnt out hulks for the battle field.
Shagnifico 04-11-2006 06:18 PM
ORIGINAL: Shagnifico
Shagnifico 04-12-2006 08:14 AM
Is there a way that I can just hook the smoke unit straight to the battery power in the tank ?
Stang951 04-14-2006 12:42 PM
Yeah anything is possible. You could easily put a switch with jumpers over to the smoke unit. But then it would run all the time.
The other thing you could do is test the switch on the large board to make sure that it is letting power through it. I would do that before going through the trouble of making a whole seperate circuit for the smoke unit. I will admit though if HL had made thesmoke, motors, sound and other functions on seperate boards things would be easier for us to re-engineer and make better. f you need seomthing else let us know.
Shagnifico 04-14-2006 03:24 PM
What are jumpers ?
Shagnifico 04-14-2006 05:46 PM
I fixed it.
Wired the smoke unit from the battery and put a switch under the commander's hatch. I also put the antena on the turret where it's supposed to be.
Stang951 04-14-2006 08:02 PM
Sounds good. how does the smoke umit work hooked direvtly to the batt? any difference?
Shagnifico 04-17-2006 09:19 PM
No different. The new units seem to smoke more but they're just as noisy. It's nice not having to open the battery compartment to turn the smoker off or on.
Harquebus 04-17-2006 09:26 PM
Shagnifico:
Do you have to worry about tangling the (antenna) wiring now that the antenna is mounted on the turret?
It's nowhere near a true 360 degree rotation anyway, is it?
-Harq
Shagnifico 04-17-2006 11:54 PM
Well I don't worry about it anymore than any of the other wires that go to the turret.
The turret rotation is quite near 360 degrees. I would estimate 340.
