RE: Pershing Progress....so far
Maybe that's a picture of my lunch...ramen noodles....lol.
Dennis |
1 Attachment(s)
Gear stowed! I'm experimenting with microballoons and acrylics paint....looks like it makes good "mud"
Later, Dennis |
1 Attachment(s)
While I detail my tank I've been working on my first village building...here is a pic of the progress on that.
Question about tread tightness...mine crackle as they turn are they too tight? THanks in advance. Dennis |
1 Attachment(s)
Did you use a primer before application of the olive drab paint? Also, have you used a dull coat or is what we're seeing just a paint and wash layer?
Great job on the tiedowns! I don't know why but they really add to the look of the tank. Is this the paint you used? -Harq |
1 Attachment(s)
Yep...used testors primer-gray...on everything. Haven't used a dull coat...thinking about it. It is just paint and wash right now.
This is a picture of the paint I used. Thanks...for the tiedowns I drilled holes at an angle on either side of the handles and passed a wire through then pulled the string through. Later, Dennis |
Comments, comments... I know. :eek:
I know the turret has a noticeable seam dividing the top and bottom halves. Can this be filled with putty/epoxy or should it be left alone so one can disassemble the turret for maintenance issues, etc.? Just striving for my own little version of a realistic Persh'. -Harq |
I know the turret has a noticeable seam dividing the top and bottom halves. Can this be filled with putty/epoxy or should it be left alone so one can disassemble the turret for maintenance issues, etc.? ......just my opinion, though. Jason |
| All times are GMT -8. The time now is 10:34 AM. |
