RCU Forums
-   RC Tanks (https://www.rcuniverse.com/forum/rc-tanks-369/)
-   -   Lubrication (https://www.rcuniverse.com/forum/rc-tanks-369/5316299-lubrication.html)
944 01-24-2007 01:50 PM
Lubrication
What lub is best for the gearboxes of an early Tamiya King Tiger?
Turret gearbox has lots of nylon. Could I use silicon spray?
What about motor cycle chain lub for the drive? It is designed not to harm rubber & nylon and is very thin when applied but thickens after a few seconds.
Mike.
chickster 01-24-2007 02:26 PM
RE: Lubrication
put on what it calls for tamiya lube
heavyaslead 01-25-2007 08:34 AM
RE: Lubrication
When you run out of Tamiya grease, I found white Lithium grease works well.
I would avoid automotive lubricants since they are generally designed for high speed uses where the viscosity will change to an optimum performance level at those high speeds.
