Spektrum DX6/BR6000 receiver plug help
I searched here, the DAK, and the BAT sites.
I can't seem to find the info I need. So I managed to bind the receiver to the TX. I plugged in the channels in 1,2,3,4 order but this does not control the tanks normally. I want my DX6's right stick to control the tank's movement and have the left stick control the turret. Can anyone tell me what channel wires from the DMD I stick into which slots on the receiver? I guess a good answer to know is what does each channel 1,2,3,4 actually control in these tanks? Thanks! Tak |
RE: Spektrum DX6/BR6000 receiver plug help
If you don't have the manual to go with the DMD, I would stick one wire at a time into the receiver ELEV channel and push the right joystick up/down to see what it does.
Receiver Channels: * THRO (throttle) - Channel 1: left stick up/down * AILE (aileron) - Channel 2: right stick left/right * ELEV (elevator) - Channel 3: right stick up/down * RUDD (rudder) - Channel 4: left stick left/right * GEAR (retracts) - Channel 5: top left toggle switch * AUX1 (flaps) - Channel 6: top right toggle switch |
Figured it out.
Tamiya channels: 1 Drive turn 2 Drive forward/rev 3 Turret up/down 4 turret rotate So for Left stick turret and right stick drive I have the following 3 to THR 1 to AILE 2 to ELE 4 to UD New problem, how to get the guns to fire. I tried the tutorial off the DAK site and this didn't work, nor does it explain how to get the machine gun to fire. Does anyone have a DX6 with the right stick for movement and the left for turret? Can you tell me how to set this radio up to move and fire? |
You can reverse the channel in the DX6 transmitter.
| All times are GMT -8. The time now is 10:54 PM. |
