Help!!!!
hai i'm tsc remember the me who owns the henglong tiger tank which i burn the pcb boar, well good news is that i bought another tank to replaze it,paint it to a new colour. now after i move the main board, for a few days good things, i played the tank all over the house and my backyard, but after 3 days, it stop moving. when i pluc in the battry the tank moves it self, it tried open it up the tank, nothing burn... than sudenly while the battry still plug to the tanks, smoke begins to emmerge, not from the smoke unit but from the pcb, what went wrong? i don't understand, it's new why? any body can give me advice? don't tell me i have to buy new tank? Please if i do need to buy new tank i think i'm going to quit playain tank and start playing rc cars again........
RE: Help!!!!
Hi tsc,
Sorry to hear about your board. You do not have to replace the tank because you can buy replacement parts (boards, transmitters, tracks etc) from a Canadian company at www.matotoys.com . Check out their site and order what you need (always a good idea to bulk buy some boards) and it works out cheaper than replacing the tank. I must add that I have been extremely lucky so far and have never had a board failure. This is pretty amazing considering I have 10 Henk Long tanks and I run them pretty hard outdoors. Best of luck. Cheers :) Mario |
RE: Help!!!!
try to avoid "stalling" the drive motors etc. also avoid sharp turns on carpet etc where the tracks catch the carpet and pull. it is very hard on the motors.
RE: Help!!!!
well i've open up my tank again and try it runnng, everything works, the cannon eleveting, bb gun firring, foward, reverse, smoke unit and sound all orks, except the turret movment. it does not turn left and right, i check the board but all sems ok, no cut of wire and the resistor that i have mention, it's still working when i test it with multi testor.....any body knows or expirience the problem i had? real need our help...bad luck hae been following me....
RE: Help!!!!
you might want to also consider the transmitter. I've had a few flaky switches on mine. Most likely your main board though.
Perry |
RE: Help!!!!
One of my tanks blew the transistor that operates the turret once. To replace it would cost nearly as much as a new board. If you like the hobby, buy a bunch of spare boards.
RE: Help!!!!
the transmitter wuld not be the problem because when i push the tranmitter stick left and right , there is urning sound from the speaker, and for the transistor, i do not know which tansistor for the turet, any refrence shot for me or guide line ......
| All times are GMT -8. The time now is 05:07 AM. |
