Tank Plans
Hey Fellas!
I've been kicking around doing some scratchbuilt tanks since nobody makes them in 1/16 scale. Where would I get the plans for them? I've seen guys with plans for the Panther where they simply made a trace of the slab of armor and traced it right onto the material to be cut. I'd like something like that but anything is a start. Anything you can provide would be greatly appreciated! |
RE: Tank Plans
paper models? heaps can be found on P2P programs, just look for "Papermodels@Emule" or just "paper model ______ " (insert tank name). Theres tons out there!!
RE: Tank Plans
P2P??? Like Limewire? [sm=confused.gif]
RE: Tank Plans
Shareaza!! :)
Kazaa was great, then Limewire, now its Shareaza |
RE: Tank Plans
I would love to make a Ferdinand......:D:D
Think They have that in a paper model? |
RE: Tank Plans
1 Attachment(s)
Would an Elephant do?
(Papermodels@emule) [GPM 147] [Armor] SdKfz 184 Tiger I (Elephant).pdf - 39mb Have attached some pics of the complete paper model in 1/25, and an example of the plans |
RE: Tank Plans
Here are some site I've run across
http://cardmodelshop.com/store2/prod...fb9eab23e9369e http://www.papermodelstore.com/advan...8229a6&x=0&y=0 If you look at Merle Mohring's Elephant on our site, he started out with a paper model, and scaled it to fit an old King Tiger chassis he had. In first few photos you can see the paper pattern's camouflage still on the tank. http://web.mac.com/ksoc/Special_Proj..._184_Ferd.html Good luck |
RE: Tank Plans
I bought a cheap 1/35 scale Jagdpanther and made plans from that-
http://i19.photobucket.com/albums/b1...anther/ht1.jpg |
RE: Tank Plans
If you have ACAD you can make a very accurate as I did for the Zrinyi:
http://www.sead.us/Zrinyi-Eric-Views.pdf |
RE: Tank Plans
I looked, no M18 Hellcats. [:o]
RE: Tank Plans
ORIGINAL: wackywheelz Would an Elephant do? (Papermodels@emule) [GPM 147] [Armor] SdKfz 184 Tiger I (Elephant).pdf - 39mb Have attached some pics of the complete paper model in 1/25, and an example of the plans SURE DOES!!!!!! Thansk Very Much WACKYWHEELS |
RE: Tank Plans
No problems mate, glad to be of assistance :)
RE: Tank Plans
1 Attachment(s)
Wozwasnt can you give me the measurement I have indicated on your drawing? I need to check an enlargement of a paper model I enlarged from a printout of the pdf tank file
RE: Tank Plans
1 Attachment(s)
Whipped up a diagram of a 1/16 Jagdpanther
RE: Tank Plans
Thanks whacky
RE: Tank Plans
I got almost the same as Wacky's - 343.5mm
RE: Tank Plans
Well both are within reason as long as I apply the same resizeing to everything no one will notice a 2-3 mm difference
RE: Tank Plans
RE: Tank Plans
I knew it LOL [:-] very funny whacky
RE: Tank Plans
If you're printing out PDF's then make sure that the plans are all in the same direction ie the front of the tank is always facing the top.
A lot of printers distort an image (usually length ways) as the paper feed isn't 100% accurate. Even top end printers can have this problem. |
| All times are GMT -8. The time now is 10:21 AM. |
