RCU Forums
-   RC Tanks (https://www.rcuniverse.com/forum/rc-tanks-369/)
-   -   Help, help, help!! (https://www.rcuniverse.com/forum/rc-tanks-369/6645989-help-help-help.html)
Tanxalot 11-19-2007 04:50 PM
Help, help, help!!
I know I shouldn't have done it, BUT...I bought a 2nd hand HL 1/24 scale Leo 2...
sorry, I know it was dumb, but I really wanted one, and it was reasonably cheap on the auction site..and, well you know what its like!!
Well, just gave it it's first run...yikes!! flat out or nothing...wow!! Turned like its on steroids, then noticed it didn't want to anymore, well at least in one direction, then it started pulling to one side... had a look and noticed several bits of plastic on the floor .....oh oh!!...what do we have here...aha...missing bits from the rear drive cog!!!. Yep, the cog has lost all the little bits of plastic that the central track splines engage with for propulsion. The Leo is in trouble already!!
Any suggestions (other than burn it!!) for a repair folks? Please??
wackywheelz 11-19-2007 09:41 PM
RE: Help, help, help!!
LOL "how the?!". First time I've heard this one (sprocket damage)
shenlonco 11-19-2007 10:28 PM
:)Not the first time i heard this problem in HL 1/24 tanks!!
What you can do is get brass tubing at a hobby shop that is the same diameter as the plastic sections that fell off and also buy a drill bit the same size as the brass tube ...you then need to drill through the sprocket where the marks are left from the plastic sections falling off ..then cut the brass tube to size and push them through the holes you drilled and CA glue them in place.
fv432 11-20-2007 10:11 AM
tanxalot pm me i have loads of spares even brand new track for the leo and two bodies if your interested?
dont want anything for the parts so let me know;);)
Tanxalot 11-20-2007 02:57 PM
Thanks Guys, and fv you have mail!!
fv432 11-20-2007 04:14 PM
1 Attachment(s)
here you go tanxalot a few piccies of what's in the box;)
fv432 11-20-2007 04:20 PM
picture 8 shows the same problem with the broken drive splines
Tanxalot 11-20-2007 04:55 PM
Cheers Fv sent you a pm Thanks
pooka2hot4u 11-20-2007 04:59 PM
shouldnt the teeth on the sides of the sprocket have engaged the sides of the treads like on the real one?
Tanxalot 11-20-2007 05:07 PM
Unfortunately not!! These things have a "false" sprocket, the "drive" is via the rather puny central splines and the outer teeth are purely cosmetic.....nasty!!
fv432 11-20-2007 05:08 PM
in reallity yes but we are talking a 1/24 model by hen long so what ever works for them
fv432 11-20-2007 05:10 PM
damn you beat me to the reply LOL;):D:D:D
Tanxalot 11-20-2007 05:18 PM
AT LAST I BEAT SOMEONE...HOORAY!!!!!!!!!!!!!!!!! LOL!!
fv432 11-20-2007 05:24 PM
ROFLMAO:D:D:D:D:D:D:D:D:D:D
