RCU Forums
-   RC Tanks (https://www.rcuniverse.com/forum/rc-tanks-369/)
-   -   HL Tiger electrics (https://www.rcuniverse.com/forum/rc-tanks-369/6868192-hl-tiger-electrics.html)
manuerg 01-07-2008 10:50 AM
HL Tiger electrics
Hi,
I have a small problem in that my Tiger main board does not seem to communicate with the turret (mainly!) The red(?) LEDs come on and work OK, changing from blinking to constant when I press the starter. But none of the turret functions work. If I apply a voltage direct to each motor - turn and elevation -each works OK. Neither work when I connect to the loom.
This is the second main board I've tried with the same result, so I do not suspect the board.
Has anyone else had this problem? Any help would be appreciated.
Thanks.
blitzkrieg65 01-07-2008 11:04 AM
RE: HL Tiger electrics
1 Attachment(s)
Here is the circuit you can make sure that you are wired correctly or that you are getting good contact from here!
The Blitz
swathdiver 01-07-2008 11:12 AM
1 Attachment(s)
You trying to confuse the man Blitz? That's a conversion wiring diagram! :D
The ground wires control the functions in HL tanks, many people think it's the red and wire their tanks up wrong.
blitzkrieg65 01-07-2008 11:28 AM
True it shows how it connects to the T-34 I guess I should have pointed that out,:eek: but at least he could see what & where the source is;)
The Blitz
wackywheelz 01-07-2008 11:37 AM
Make sure you're plugging it in all the way, use a multimeter to check the pins on the loom coming from the board, especially the red and black on the edge (turret rotation) -- under power it should give 6.8-7.2v
Check your wires arent cut/crimped... I dunno what else to say
manuerg 01-08-2008 04:11 AM
Hi Guys, and thanks for your advice. I too have run out of ideas, which is why I posted the plea for help!
It's going to be something simple - many of these things are - and I guess I will have to go back to basics and check the wiring right through from start to finish and not assume anything is right!
The fact that none of you, with your combined experience, have knowledge of any similar board problem is encouraging. My own "gut" feeling is the connector, but I may well be wrong! Aren't we all at some time?
swathdiver 01-08-2008 05:28 AM
You probably got the 3 wires going from the turret to the junction block crossed and that's why nothing up there is working.
manuerg 01-08-2008 05:53 AM
It's something to consider, Swathdiver. I'll check it out in relation to the circuits that have been posted on this forum. As I'm sure you appreciate, I'm grasping at straws on this one!
wackywheelz 01-08-2008 07:11 AM
http://members.iinet.net.au/~wackywh..._8pin_plug.jpg
Taken from my thread [link=http://www.rcuniverse.com/forum/m_6571532/anchors_6573955/mpage_1/anchor/tm.htm#6573955]here.[/link] Hope it helps
manuerg 01-08-2008 07:46 AM
Thanks Wackywheelz. Also had a look at your other thread out of interest. Few of the colours coincide, but it's where they go that counts.
wackywheelz 01-08-2008 07:53 AM
Yep, wire colours/colors may vary, but placement is always the same (on the plug). I was gonna put that on the image, I host the image locally (in my own webspace) so it can be easily edited to clarify or correct something. Good luck with getting it back to life, shouldnt take much!
- wacky http://members.iinet.net.au/~wackywheelz/wakky.gif
YHR 01-08-2008 11:12 PM
ORIGINAL: manuerg
Don't rule out a problem with the transmitter. I pulled a tank apart one time thinking the grounding wire off of the elevation motor came off. After I got the thing torn apart, and found the wiring to be intact, I focused on the transmitter. Turned out the gimble on the left stick was the problem. I had to re-adjust the contacts and then everything was fine.
manuerg 01-09-2008 05:22 AM
Hi YHR,
I hadn't even considered the transmitter until now but, now I come to think back to when the problem all started, the TX could well be the problem. Thank you for the idea. I have a spare TX, so will have a go at that.
manuerg 01-09-2008 09:21 AM
Hi YHR,
Brilliant! It all works OK. Thanks for that. When I looked at the Tx, neither of the contacts was making contact with the board. A few tweaks, and it all works fine.
Lessons to be learned here, guys!
wackywheelz 01-09-2008 09:27 AM
LOL, does happen. Trial and error, sort through what is working to eventually find what isnt [8D]
Glad its all fixed.
blitzkrieg65 01-09-2008 12:53 PM
That is why this forum is so great! Nice work YHR two heads are better then one and a couple hundred is a library!:D
The Blitz
YHR 01-09-2008 07:44 PM
ORIGINAL: manuerg
Hi YHR,
Good news. Glad I was able to help. This forum has taught me a lot, and without it I would have been lost with these Heng Longs. It is nice to be able to give something back.
