broken wire?
hi
I found one of the black wires leading into the turret has broken half way, but cant seem, to find the other half in the turret. can anyone tell me where it goes too? Tank you |
RE: broken wire?
Test your functions, find which isnt working then report back :)
(making sure the wire doesnt touch on anything while its loose) |
RE: broken wire?
BB not firing
RE: broken wire?
1 Attachment(s)
hi xt,
don't want to but in while whackwheels is helping but i just happen to have a few photos taken while working on a tiger, i'll try to post them if they don' t appear, sorry regards jack. |
RE: broken wire?
Its the red wire in your pictures thats the culprit. That go to the red firing led?
RE: broken wire?
Don't you just love Heng long and their color coding. Every tank is wired with different color wires.
I warmed up a DBC IC chip because the orange/brown/red connections between the ESC and the receiver were opposite on one of my tanks. The previous 6 were all the same so I thought they had that part of the wiring nailed down, but I found out this was the wrong assumption to make.:D |
RE: broken wire?
1 Attachment(s)
Here's my infamous turret wiring diagram. These are the two ways I've seen the turrets wired up. There is no standardization of colors. The ground wires are the control wires, everything gets power, the grounds are turned on and off by the electronics.
RE: broken wire?
1 Attachment(s)
yes, it's soldered to a black wire and both go onto 1 led of the red led
RE: broken wire?
ORIGINAL: xander_trippin BB not firing Just so you know this gun must be wired right or the gun can be dammaged,if when you test it and it starts clicking "STOP". It is not wired to run the motor in the right direction if it does this,and then the wires must be reversed.I have done this before and got lucky and didn't hurt the gun. BIGMIG ;););) |
RE: broken wire?
Cheers Guys!!! got it fixed now. Thats the problem i have with 360 turret
| All times are GMT -8. The time now is 01:48 PM. |
