RCU Forums
-   RC Tanks (https://www.rcuniverse.com/forum/rc-tanks-369/)
-   -   engine cut-out (https://www.rcuniverse.com/forum/rc-tanks-369/7744993-engine-cut-out.html)
perrye 07-18-2008 11:05 AM
engine cut-out
I just got my first scratch built plane up and flying it was a Dazzler. I had one successful flight then on the second flight I started to do maneuvers and the motor cut-out. I believe it was caused from the pick up in the tank not getting to the fuel. The plane was doing a loop then an aileron role, leveled out made a left turn, sputtered then cut out. The motor was a .40 LA the tank was 6 oz. Is that the reason and if it is how do I fix it, if not the reason what could it be. I also have a external fuel filler in the line up. Thank you, E
nomobux 07-18-2008 11:09 AM
RE: engine cut-out
ORIGINAL: perrye
Wrong tanks !! :D:D
Ern 07-18-2008 11:20 AM
RE: engine cut-out
If your scratch built has metal gears and tracks it may be a little to heavy to do a loop and aileron role and then go immediately into a left turn :D
Sorry... I couldn't resist!
pattoncommander 07-18-2008 01:04 PM
RE: engine cut-out
think your left track tension is off and turet treverse motor needs servicing. :eek:
971wright 07-18-2008 02:11 PM
RE: engine cut-out
the only things that fly on this forum are funny answers .
regards pete
bowlman 07-18-2008 02:30 PM
RE: engine cut-out
1 Attachment(s)
we could make one of them russian flying tanks that ive seen on the military channel that was on the drawing board I think they tested one and found that the consept was not worth it . ya a t34 with wings
thanks
jimmy
swathdiver 07-18-2008 04:24 PM
RE: engine cut-out
Water in fuel. Check your fuel/water separator! :D
OliverLove 07-18-2008 05:33 PM
RE: engine cut-out
I would have used the 8 oz tank instead of the 6oz, you clearly underestimated your fuel economy.
g.horn 07-18-2008 06:27 PM
RE: engine cut-out
Shorten the pick up tube' and roll the plane by hand and make sure it will flex to all points on the tank and does not hang up.
Greg
pattoncommander 07-19-2008 10:02 PM
RE: engine cut-out
that's it! gotta be the fuel tank...most tanks only get 3-4 gallons per mile and flying requires a lot more. :D
Ern 07-20-2008 01:26 PM
RE: engine cut-out
I don't know, I think you were onto something there with the left track tension. Maybe adding a link to the left side would correct the problem :)
Panther G 07-21-2008 12:39 PM
RE: engine cut-out
Ahhh you guy's kill me.
Matdragon 07-21-2008 12:52 PM
RE: engine cut-out
lol, dont be harsh. he made a simple mistake - thats all! how about if you started talking about track tensioning in the plane section! how would you like it! :D
pattoncommander 07-21-2008 08:28 PM
RE: engine cut-out
what would the world be with out humor:D:D
