RCU Forums
-   RC Tanks (https://www.rcuniverse.com/forum/rc-tanks-369/)
-   -   Remote problem (https://www.rcuniverse.com/forum/rc-tanks-369/7805100-remote-problem.html)
jmcnulty 08-03-2008 09:04 PM
Remote problem
I have 2 new metal bulldog tanks and 2 controlers on channel 3. I was using one remote for each tank. All of a sudden I cannot get the tanks to activate with the remotes. Any combination with fresh batteries. I have 2 tanks that don't work or 2 remotes that do not work. What could be happening? It happened all of a sudden. I can get one tank to turn over but not operate if it touch the antennas together and hit the key it wil not go forward or reverse or resond to the remote after that. What could have fried? I could see one not working, but a problem with all of them?
Jack
wackywheelz 08-03-2008 09:10 PM
RE: Remote problem
Have you played around with the crystals, as in removed them?
blitzkrieg65 08-03-2008 09:13 PM
RE: Remote problem
First place to start is the crystal on the transmitter! Pull it out and widen the legs so it is fitting tightly into the slot in the radio! Did that help?
The Blitz
brel 08-04-2008 01:15 AM
RE: Remote problem
also check the crystal in the tanks, I had a similar problem and found it was the crystal in my snow leopard to be loose in its socket.
jmcnulty 08-04-2008 07:12 AM
RE: Remote problem
I tried pulling them out and putting them in. No change. Could I have burnt them out? Thanks -Jack
RCCOMMAND 08-04-2008 09:55 AM
RE: Remote problem
ORIGINAL: jmcnulty
I can send you a couple of crystals if you want to start there. Just PM me your address.
Bill
