RCU Forums
-   RC Tanks (https://www.rcuniverse.com/forum/rc-tanks-369/)
-   -   El-mod ... ??? (https://www.rcuniverse.com/forum/rc-tanks-369/8012593-el-mod.html)
Matdragon 10-02-2008 01:57 PM
El-mod ... ???
hey guys,
as some of you probably know im planning a HL super pershing build, not as i really dont like the sounds of the HL, i am considering fitting HL with the rx14 board, but i dont know what i would need? ive looked on the sight and saw that the thinktank blaster appears to be el-mods sound module, but can this be fitted directly into a HL tank along with HL's electronics and receiver?? or would i need other el-mod items too?
thanks, and while im at it which el-mod parts would i need to use the el-mod battle system? or could i still run the DBC/DBU with the required el-mod stuff to run the blaster? [:-][sm=bananahead.gif][sm=bananahead.gif][sm=confused.gif][sm=confused.gif][sm=bananahead.gif]:D:D
thanks guys, sorry im a bit of a newbie with el-mod. :D:D
cheers guys, i eargerly await your responses!!! ;);):D:D:)
Matt
jakeand 10-02-2008 03:04 PM
RE: El-mod ... ???
Hi Mat,
"directly into a HL tank along with HL's electronics and receiver??"
From:http://www.el-mod.de/product_info.ph...ed2b1be763c838
"A ThinkTank Booster is necessary, ThinkTank TLS is strongly recommended as otherwise there will be no sounds for the turret functions"
But you can hook this up with HL electronics/reciever, watch this excelent work by Swathdiver: http://www.rcuniverse.com/forum/m_65..._6/key_/tm.htm
"or could i still run the DBC/DBU with the required el-mod stuff to run the blaster?"
Sorry, dont know I hope that "Blitz" can fill me in.
Regards jake
blitzkrieg65 10-02-2008 03:19 PM
RE: El-mod ... ???
Regards jake
[/quote]
Well this had not been tired,,, in therory this may work but you have two systems changing the drive function so that maybe a problem? EL MOD has a battle system the CSI $ 110.00
You already have a Futaba radio just buy anohter receiver and junk all the heng long stuff and go all EL MOD, that is another option!
The Blitz
Matdragon 10-02-2008 04:26 PM
RE: El-mod ... ???
Hey Blitz,so can you please put me straight ... i dont really want to go all elmod as i havent got the money for that, but i would like the elmod sound, so what is the easiest way of doing this?? thanks blitz, any help is appretiated!!
cheers,
matt
blitzkrieg65 10-02-2008 05:06 PM
RE: El-mod ... ???
ORIGINAL: Matdragon
cheers,
matt
You know I think it might help for me to give an analogy to the mind of EL MOD! Think of it as a primitive robot mind, with all functions for sending a signal to simple device or intelligent system to make what moves or sounds or pulse,,,, it will be carrying it out! For example the sound Blaster is a 10-watt Stereo, which the sounds are only starting by a certain signals from the EL MOD processor, or Brain that is calculating Physics the type of terrain it comes up against! Now this is just my explanation of, but I hope that explains why it is impossible to use the Blaster II with any other electronic system!
The Blitz
Matdragon 10-03-2008 11:15 AM
RE: El-mod ... ???
oooookk......
right,you couldve just said no, but everybodys different!! :D:D
so what other elmod stuff do i need to run the blaster?
thanks,
Matt
blitzkrieg65 10-03-2008 01:23 PM
RE: El-mod ... ???
ORIGINAL: Matdragon
oooookk......
thanks,
Matt
:D:D:D Ya I guess I could of said that each unit needs to give and receive data but I think it still puzzles folks,,, but I might be wrong!;)
Booster/ TLS / Blaster II you need EL MOD to run EL MOD, it is like changing you tank over to a Tamiya Tank, but with additional features!
The Blitz
971wright 10-03-2008 01:34 PM
RE: El-mod ... ???
Matt the advantage of el-mod is you can buy it a bit at a time start with the bigboost and prop 4 then later you can buy the TLS then you can buy the soundmdule so even though its not cheap it can be affordable this way if you look at the way you buy it it will fit in with any build first you build the hull buy the bigboost with prop 4 then you test your running gear then you start to build the upper hull you buy the tls and test then paint and finish your tank then buy sound module to finish it hope this gives you something to think about .
regards pete
percy1510 10-03-2008 01:50 PM
RE: El-mod ... ???
Intersting thread this. I am planning to do a panzer 4 with all the elmod stuff as listed in this thread but my question is can I still fit one of the recoil units that I keep seeing on ebay ?
971wright 10-03-2008 02:06 PM
RE: El-mod ... ???
Ive seen it done but you will have to ask Blitz how its wired in .
regards pete
Matdragon 10-03-2008 03:40 PM
RE: El-mod ... ???
yes thanks guys, im going to get the bigbooster first, then TLS and the blasterIII!! :D:D
i also would like the re-coil unit but dont quite know which one will run with the HL/el-mod stuff ...
thanks guys for your help..:D:D
Matt!!
mickyb 10-06-2008 02:57 PM
RE: El-mod ... ???
Hi there Mr Blitz......
My names Mike and I have just started this hoby and got well and truly hooked. I asked a question on here about electronics and one reply said that you supplied a guy in UK with El mod kit.
I have HL PZ3, PZ4 and a Tiger in pieces, will El mod fit in all of them? I want gun and engine sound plus future battle system is this feasible in all 3 tanks or is the PZ3 too small?
Last of all, will all the HL electronics be binned during the conversion or do I utilise some of it. I am not electronics friendly at all but I am more than willing to have a go. Having said that, the write ups on El mod have confused me completely....I am over 60 so senility is kicking in!!!
Do you supply to UK customers still please, if so what will it cost per tank for sound upgrade?
Thank you in anticipation of you taking pitty on an old man.....Mike
blitzkrieg65 10-06-2008 04:11 PM
RE: El-mod ... ???
ORIGINAL: mickyb
Hello there Mickyb, you have just caught me at a busy time trying to get caught up, but getting close! I do supply the UK, and yes EL MOD will work and fit in all those tanks!
The Electonics and sound upgrades will be about $ 290.00 a tank, give or take $ 15 depending on what system you want! BAD NEWS right now and unitl possibly early December I will not have the EL MOD version that lets you use the Heng long Radio! I do have other versions in stock but you will need to buy a high end radio to operate!
I have to make a post office run right now, and it is easier for to meet you individual needs please e-mail me at; [email protected]
The Blitz
RCTankWars.com
Wibblywobbly 10-14-2008 11:31 AM
RE: El-mod ... ???
1 Attachment(s)
Is it me or is the El-Mod site the most confusing place on planet Earth?
I have a Heng Long Tiger 1. Full Metal options fitted eg tracks, gearboxes, suspension, hatches etc etc. It weighs a ton!
I am trying to figure out how much I need to spend to convert it to the ElMod system so that I get the sound, proportional speed and turret rotation, whilst keeping the airsoft gun, and if possible the smoke unit? I cannot figure out what I should be buying??
Just to complicate matters I would dearly love to get hold of the Creeping Death Tiger Turret so that I get an airsoft gun, plus laser with extended barrel and recoil.
On top of that I am looking at fitting some decent motors. Though only if they improve on the whitecaps that are currently installed.
I am happy to buy a new tx.
(I daren't mention that I am also an old fossil from the UK who works in IT, I still have trouble with a video remote??).
Can anyone list the parts I need, and the cost either direct from ElMod or the U.S. I would be very grateful.
Hoping there is someone out there willing to take pity on a befuddled Brit!
Cheers
Rob G
icemonkey 10-14-2008 12:01 PM
RE: El-mod ... ???
hi ,you would need the thinktank booster hl/m, thinktank tls and the thinktank blaster 2, comes to about £170, i got mine from blitz rctankwars.com, but he wont be getting any hl chips in till dec, but he has the prop version on the shelf
Matdragon 10-14-2008 01:50 PM
RE: El-mod ... ???
what re-coil can i use with HL/El-mod?
thanks,
Matt :D
icemonkey 10-14-2008 01:57 PM
RE: El-mod ... ???
1 Attachment(s)
you can use this one or the tamiya one ,but with the tamiya one you need to ad some resistors and a diode
Matdragon 10-14-2008 02:10 PM
RE: El-mod ... ???
hey thanks, i think ill use this one, but may i ask what this one is??
thanks,
Matt
icemonkey 10-14-2008 02:34 PM
RE: El-mod ... ???
this one ,is the one ive got
:D:D:D,, sorry cant remember at the moment, but you can get it on a certain bidding site
Matdragon 10-14-2008 02:49 PM
RE: El-mod ... ???
thanks, so i guess you have HL/El-Mod in the tank equiped with that re-coil unit?
and if you remember that name .... please let me know!! :D:D
thanks,
Matt
icemonkey 10-14-2008 02:56 PM
RE: El-mod ... ???
yes its in a post on this forum,rctankwarfare,[X(][X(][X(]:D:D, you should join lol
Matdragon 10-14-2008 02:58 PM
RE: El-mod ... ???
i must be stupid, i cant find any re-coil units on the bay... [:o]
Matt
Matdragon 10-14-2008 03:00 PM
RE: El-mod ... ???
ORIGINAL: icemonkey
dont know if you know, but i made that forum LOL :D:D
Wibblywobbly 10-14-2008 03:06 PM
RE: El-mod ... ???
Why buy a recoil unit when you can buy the whole turret with upgraded gun etc from Creeping Death??? It makes no sense. I just ordered one.
[link=http://creepingdeathrc.netfirms.com/seekndestroy//catalog/index.php?cPath=30&osCsid=20401f90db181c7966ba809e 593bf755]Tiger Turret[/link]
Rob G
jakeand 10-14-2008 03:07 PM
RE: El-mod ... ???
Hi Mat,
Check this:
http://www.asiatam.de/product_info.p...8bcfd601484633
or:
http://www.rctank.de/product_info.ph...roducts_id=431
Works with HL electronics and radio. Its also possible to use with El-Mod, but then its not "Plug and play"
Regards
Jake
