WSN Tiger I
Hello everyone,
I had the opportunity to pick up the winter scheme WSN T34/85 for a bargain a while back, and now have the chance to purchase the WSN tiger for around the same money. Is it possible to fit HL metal tracks to these tigers and does the barrell length need adjusting like the HL Tiger I? |
RE: WSN Tiger I
Had one of the WSN Tiger before. I think the barrel length is slightly shorter, but definitely not as bad as the HL Tiger. Personally, I'll leave it alone.
As for metal track, I'm not sure whether it'll fit, but even if it is possible, I don't advise you doing it - the stock plastic gearbox is too weak and not enough power. You'll have BIG problem running it with metal track anywhere except smooth surfaces. |
RE: WSN Tiger I
Ditto what Calvin said regarding the tracks and gearboxes, and gun barrel. Despite the weak gearboxes I think the WSN is a nice tank for the money that can also be upgraded according to your needs. The detail is at least as good as the HL Tiger, plus the cannon and MG firing sounds are way better IMO than the pathetic firing sounds on the HL tanks, especially on those with the RX13 boards, and the paint job on the WSN is far superior to anything HL has offered on the US market.
RE: WSN Tiger I
You could always upgrade the boxes to tamtoys low profiles using my T34 build as reference Beef up the inner floor pan and stick in H/LONG leccies or tam DMD MFUs just another option;);)
Kind regards Rob |
RE: WSN Tiger I
Awesome, thanks for the input guys.
I agree with ostketten regarding the firing and MG sounds, althought it's a little annoying having the MG sound whenever you elevate the barrell. Is it possible to fix this and retain the original sounds without going to a HL board? |
RE: WSN Tiger I
as far as iam aware the sounds will stay and there isnt much can be done
not to sure on the later wsn boards as not to much is known about them but if they are the same as mine then the H/Long boards are a 100% improvement drivability wise and sound wise IMHO Kind regards Rob |
RE: WSN Tiger I
ORIGINAL: h8ted I agree with ostketten regarding the firing and MG sounds, althought it's a little annoying having the MG sound whenever you elevate the barrell. Is it possible to fix this and retain the original sounds.... |
RE: WSN Tiger I
Thanks for all the help.
I might eventually gut both the Tiger and the T34/85 and put all new HL gear in them (now HL do IR as well). |
RE: WSN Tiger I
ORIGINAL: h8ted Thanks for all the help. I might eventually gut both the Tiger and the T34/85 and put all new HL gear in them (now HL do IR as well). |
| All times are GMT -8. The time now is 03:37 PM. |
