need help on pershing wiring !!!!!
Hey all
I need to know were the red & black wires go for the air soft shot light (LED). MY GUN AND LED ARE NOT WORKINGhttp://www.rcuniverse.com/forum/js/f.../sad_smile.gifhttp://www.rcuniverse.com/forum/js/f.../sad_smile.gifhttp://www.rcuniverse.com/forum/js/f...what_smile.gif |
RE: need help on pershing wiring !!!!!
Did you check the FAQ? or the search function? If you search, you will probably find a post with pictures. Are you talking about the red light on the mantlet that lights up when you fire the main gun? Alot of people remove this light because real Pershings didnt have a big red light that lit up when they fired:D I actually painted over it when I painted my Pershing.
1 Attachment(s)
Which end? Here's my detailed and highly technical turret wiring diagram from several years back:
1 Attachment(s)
The writing is in German, but it's not that hard to figure out what is what...
I used an online translator and started converting the writing in the second one. |
Did you check the FAQ? or the search function? If you search, you will probably find a post with pictures. Are you talking about the red light on the mantlet that lights up when you fire the main gun? Alot of people remove this light because real Pershings didnt have a big red light that lit up when they fired [img]{akamaiimageforum}/image/s2.gif[/img] I actually painted over it when I painted my Pershing. |
Tankinstein, I apologize if me post sounded sarcastic, I was in a very bad mood at the time. I should have kept my big mouth shut!
| All times are GMT -8. The time now is 12:35 PM. |
