RCU Forums
-   RC Tanks (https://www.rcuniverse.com/forum/rc-tanks-369/)
-   -   Crusader MK II, scratch (https://www.rcuniverse.com/forum/rc-tanks-369/9932498-crusader-mk-ii-scratch.html)
volvospeed 08-14-2010 05:26 AM
my new project. It will be my 3th Scratch Tank. Now, i want to build an Crusader.
Thats what i want to do
http://foto.arcor-online.net/palb/al...3236386237.jpg
For an Basis, i use some parts from http://www.asiatam.de
- Suspension Parts Panther
http://foto.arcor-online.net/palb/al...6566343235.jpg
- used Rims and Tires from an T34
- used Panzer IV wheels ( rear )
- used Panzer III Chains ( will modified this later )
- new Asiatam 3:1 Gearboxes ( very good and chepa too )
The rest i will build by myself
http://foto.arcor-online.net/palb/al...6565666134.jpg
Thats what i was doing yesterday
http://foto.arcor-online.net/palb/al...3732383936.jpg
http://foto.arcor-online.net/palb/al...6137626663.jpg
The body i build out of 2mm Polysterol
http://foto.arcor-online.net/palb/al...3933663234.jpg
So it looks like later when its done, i just put the parts in to see how it looks like. i hope it will work great, the chance is very good till now
http://foto.arcor-online.net/palb/al...6262633236.jpg
i cut a lot of brass tubes 5 and 6mm
http://foto.arcor-online.net/palb/al...6666336232.jpg
i pressed the tubes together
http://foto.arcor-online.net/palb/al...3566326233.jpg
the tubes are the new bearings (?) for the rims
http://foto.arcor-online.net/palb/al...6438613662.jpg
http://foto.arcor-online.net/palb/al...6364373662.jpg
Now, when i was buildt in the complet suspension i got the right heigt from the sprocketwheels. I buildt way to high in this, so i correct this
http://foto.arcor-online.net/palb/al...3134343335.jpg
As basic i glow some PS-Sheeds together and fill it up with Resin. Thats really strong, now.
http://foto.arcor-online.net/palb/al...3137313731.jpg
For safity i was soldering on the top of the brass and glow PS behind the spring, now it can´t Fall out :haha:
http://foto.arcor-online.net/palb/al...3035616533.jpg
Than i was building the same suspension system, like the other 4 axles to the first axles, but with different degrades ( sorry, my english is very bad )
I closed the drilled hole for th original T34 Part idle wheel
http://foto.arcor-online.net/palb/al...6362303737.jpg
Out of brass i build an own adjustable one ( don´t know the name for that thing, we call it Kettenspanner )
http://foto.arcor-online.net/palb/al...6431303431.jpg
Kettenspanner from top
http://foto.arcor-online.net/palb/al...6332663338.jpg
close to completted Suspension
http://foto.arcor-online.net/palb/al...6233643864.jpg
Next days i will build in electrical for Testdrive 8|
volvospeed 08-14-2010 05:29 AM
RE: Crusader MK II, scratch
At the first Picture you see that i build everthing together as a test. I wanted to check the heigh with this suspension. Well 1cm to high. **** happens
http://foto.arcor-online.net/palb/al...3431363930.jpg
First i screw and glow the axles together.
http://foto.arcor-online.net/palb/al...3432396134.jpg
Here you see it better
http://foto.arcor-online.net/palb/al...6430623038.jpg
Now, time to find out where the Probs are and how i can fix this.
Here...
http://foto.arcor-online.net/palb/al...3438633966.jpg
and here
http://foto.arcor-online.net/palb/al...3962333530.jpg
Allright, lets rock....
Cut out a little here
http://foto.arcor-online.net/palb/al...6461643537.jpg
and here
http://foto.arcor-online.net/palb/al...3964663561.jpg
Cut out a little from Panzer III Chains
http://foto.arcor-online.net/palb/al...6638373138.jpg
Put Resin in here
http://foto.arcor-online.net/palb/al...3938353666.jpg
Now its, strong enough
http://foto.arcor-online.net/palb/al...6336363362.jpg
Inlay for Electricalstuff
http://foto.arcor-online.net/palb/al...6262643462.jpg
New Optik for Idle Wheel
http://foto.arcor-online.net/palb/al...6161346335.jpg
drilled a lot of holes into the tyres
http://foto.arcor-online.net/palb/al...3666643831.jpg
Gearboxes
http://foto.arcor-online.net/palb/al...3035656232.jpg
complette with inlay
http://foto.arcor-online.net/palb/al...6135303863.jpg
http://foto.arcor-online.net/palb/al...3764616633.jpg
http://foto.arcor-online.net/palb/al...3664643237.jpg
http://foto.arcor-online.net/palb/al...6439366362.jpg
http://foto.arcor-online.net/palb/al...3463303937.jpg
http://foto.arcor-online.net/palb/al...3261323333.jpg
volvospeed 08-14-2010 05:30 AM
i buildt the little MG Turret first, so later i can see better, what i have to do and how many space i have for something else on the frontside.
First i took a 2mm pipe and buildt me an MG
http://foto.arcor-online.net/palb/al...3538303037.jpg
The turret i buildt out of 2mm PS. When i cut out the door i made an mistake  8O  i cut around forgot the little straight in there.  I glow the piece in and prime (?, with  Italeri Putty ) it.
http://foto.arcor-online.net/palb/al...3130383961.jpg
Door open
http://foto.arcor-online.net/palb/al...3936666461.jpg
en detail
http://foto.arcor-online.net/palb/al...3333623436.jpg
http://foto.arcor-online.net/palb/al...6535393463.jpg
volvospeed 08-14-2010 05:31 AM
Now i just finished the Basic Body
http://foto.arcor-online.net/palb/al...3561306164.jpg
http://foto.arcor-online.net/palb/al...3432343633.jpg
The L-Profil is for put the Chassies with this together, also for Stabilizes
http://foto.arcor-online.net/palb/al...3430386366.jpg
Outside there are 2 more L-Profils for the Fenders
http://foto.arcor-online.net/palb/al...3661373932.jpg
http://foto.arcor-online.net/palb/al...6130666233.jpg
http://foto.arcor-online.net/palb/al...3933383632.jpg
http://foto.arcor-online.net/palb/al...6433303064.jpg
http://foto.arcor-online.net/palb/al...3431373531.jpg
volvospeed 08-14-2010 05:33 AM
Today i was building the Fenders ( out of 1 and 2mm PS, also L-Profil )
http://foto.arcor-online.net/palb/al...6533333332.jpg
http://foto.arcor-online.net/palb/al...3032313631.jpg
http://foto.arcor-online.net/palb/al...3165646230.jpg
http://foto.arcor-online.net/palb/al...6139613439.jpg
http://foto.arcor-online.net/palb/al...3962353661.jpg
I buildt a little at the frant and the 4 cases ;-)
http://foto.arcor-online.net/palb/al...3937396135.jpg
http://foto.arcor-online.net/palb/al...3835353034.jpg
http://foto.arcor-online.net/palb/al...3830326331.jpg
http://foto.arcor-online.net/palb/al...3138393033.jpg
http://foto.arcor-online.net/palb/al...3130353163.jpg
http://foto.arcor-online.net/palb/al...3466383764.jpg
Today i was building at the rear side. All together i glue around 500 Screw Imitates ( Punched ), Fenderholder,Shaklesholder etc...
The 2 Boxes at the rear Deck are not finished yet, also the Airfilterboxes are not buildt
http://foto.arcor-online.net/palb/al...6538303036.jpg
http://foto.arcor-online.net/palb/al...3565373564.jpg
http://foto.arcor-online.net/palb/al...3064333934.jpg
http://foto.arcor-online.net/palb/al...3037343264.jpg
http://foto.arcor-online.net/palb/al...6462373534.jpg
http://foto.arcor-online.net/palb/al...3364643435.jpg
volvospeed 08-14-2010 05:34 AM
I tried to buildt the sprocket wheels. As Basic i used the Panzer IV Wheels. First i put in there Apoxie. Than i put this at my engine lathe ( ? ) Damn, don´t know the right word for this tool, hope you know what i mean.
http://foto.arcor-online.net/palb/al...6665356264.jpg
At least i drilled the holes in there
http://foto.arcor-online.net/palb/al...6461303634.jpg
Not 100% correctly, but much better than Panzer IV Wheels
http://foto.arcor-online.net/palb/al...3839623231.jpg
Today i finnished the sidefenders (is that right ?)
http://foto.arcor-online.net/palb/al...3662373161.jpg
The little Holders are 0,2mm thick
http://foto.arcor-online.net/palb/al...3866393565.jpg
Much better than Panzer IV wheels
http://foto.arcor-online.net/palb/al...6130313435.jpg
Looks complete different i think
http://foto.arcor-online.net/palb/al...3235396638.jpg
http://foto.arcor-online.net/palb/al...3638323038.jpg
http://foto.arcor-online.net/palb/al...6331663533.jpg
just missing gastank and airfilters than comes the turret
For today i wanted to do the Airfilters and some little details.
first i had to cut out of 10mm Brass 10 Pieces 4mm thick and drilled an whole 4mm in there. With my Proxxon, i cut the rest. Than i cut 10 Pipes 4mm and gluewed in there
http://foto.arcor-online.net/palb/al...3764653964.jpg
The Airfiltercases i build out of 2mm PS ( Polysterol )
http://foto.arcor-online.net/palb/al...3465376233.jpg
Die Airintakepipes i buildt out of 6mm Aluminum. The clamp i built out of 0,2mm phosphorus bronze
http://foto.arcor-online.net/palb/al...3939646333.jpg
The trick was to buildt them movable, so that i can remove the top section
http://foto.arcor-online.net/palb/al...3335396665.jpg
The S-Hooks out of 2mm Brass
http://foto.arcor-online.net/palb/al...3965383337.jpg
Holders
http://foto.arcor-online.net/palb/al...3063346463.jpg
more little Details
http://foto.arcor-online.net/palb/al...3961663936.jpg
Overview all new Details
http://foto.arcor-online.net/palb/al...3038373332.jpg
http://foto.arcor-online.net/palb/al...6634383536.jpg
http://foto.arcor-online.net/palb/al...6535306139.jpg
http://foto.arcor-online.net/palb/al...3961333934.jpg
http://foto.arcor-online.net/palb/al...3662333834.jpg<br type="_moz"/>
volvospeed 08-14-2010 05:35 AM
Today i was building at the Turretengine
http://foto.arcor-online.net/palb/al...3564333337.jpg
http://foto.arcor-online.net/palb/al...3535646566.jpg
http://foto.arcor-online.net/palb/al...3133396430.jpg
Crusader in Pieces
http://foto.arcor-online.net/palb/al...6265396163.jpg
i start to buildt the turret. This thing hurts me a little. i buildt it complete out of 2mm Polysterol ( PS )
http://foto.arcor-online.net/palb/al...6330646237.jpg
for the KWk Blende i use a very thin metall plate and bend this. It&acute;s a lot easier if you gue this between PS Sheeds.
http://foto.arcor-online.net/palb/al...6266346136.jpg
As Mainweapon i used the Barrel from an Panzer III. It&acute;s not done yet. The cradle it&acute;s an 12mm brass piece
http://foto.arcor-online.net/palb/al...3331393638.jpg
back to the front. i cut in 3 long wholes
http://foto.arcor-online.net/palb/al...6561396633.jpg
from inside. Mechanical stuff it&acute;s not done yet
http://foto.arcor-online.net/palb/al...3039623664.jpg
The front part of the turret is just basic. after the apoxie is try and hard i will meke the rest
http://foto.arcor-online.net/palb/al...3435383835.jpg
Today and yesterday i finnished the turret
http://foto.arcor-online.net/palb/al...3637363538.jpg http://foto.arcor-online.net/palb/al...3538353037.jpg
http://foto.arcor-online.net/palb/al...6434656136.jpg http://foto.arcor-online.net/palb/al...3934343739.jpg
http://foto.arcor-online.net/palb/al...3736643737.jpg http://foto.arcor-online.net/palb/al...3661383066.jpg
With the Turret my Crusader is complete so far :D
http://foto.arcor-online.net/palb/al...6337316265.jpg http://foto.arcor-online.net/palb/al...6330323739.jpg
http://foto.arcor-online.net/palb/al...3831653664.jpg http://foto.arcor-online.net/palb/al...6439663466.jpg
http://foto.arcor-online.net/palb/al...6430316439.jpg http://foto.arcor-online.net/palb/al...3063396132.jpg
http://foto.arcor-online.net/palb/al...6664333331.jpg http://foto.arcor-online.net/palb/al...3635306162.jpg
torpedochief 08-14-2010 06:24 AM
WOW! Show the Italian tanks you built! This will cause some major major eye popping!
Great work!!
Don
Fireman Tim 08-14-2010 06:24 AM
Davinci has been reborn! You are the Master!
I'd give my left.... (well you know) for one of those.
There must be a way to make this tank available to purchase.
Buckeye36 08-14-2010 07:48 AM
Incredible!
kclank 08-14-2010 08:59 AM
outstanding work. if i wasn't a tank junkie i would throw my tools and tanks away and just look at yours.
karel47 08-14-2010 09:43 AM
Splended work volvospeed, museum quality i look forward to see the finished model
Rex Ross 08-14-2010 09:57 AM
Absolutely stunning work. I can't believe my eyes...............WOW!
BiggTony 08-14-2010 10:14 AM
<div style="margin-top: 0px; margin-right: 0px; margin-bottom: 0px; margin-left: 0px; padding-top: 0px; padding-right: 0px; padding-bottom: 0px; padding-left: 0px; background-image: initial; background-attachment: initial; background-origin: initial; background-clip: initial; background-color: rgb(255, 255, 255); font-family: Arial; font-size: 12px; ">Justbeautifuland amazing all wrapped in one......we'll call it beautimazingful! See, I can scratch build words...so I'm okay at something! lol....I know, I'm reaching.[&amp;:]<div></div></div><span class="Apple-style-span" style="font-family: Arial; ">For a moment I thought I was experiencingdeja...but thenrememberedDon posted a link to your build from another site........At any event....Could you go into some details like, the time it took, dimensions, how to place an order? lol</span>
Flyn Chris 08-14-2010 10:49 AM
I'm speechless, what an amazing build, the amount of work is amazing. You're attention to detail is stunning.
borealis 08-14-2010 11:13 AM
Wonderful craftmanship [sm=thumbs_up.gif][sm=thumbs_up.gif][sm=thumbs_up.gif]
edoubleaz 08-14-2010 11:30 AM
I am feeling inadequate.
googlydoogly 08-14-2010 11:55 AM
Absolutely wonderful. If I have you skills, I wouldn't need Tamiya or Heng Long. :)
olfart 08-14-2010 12:48 PM
Amazing craftsmanship! Thank you for showing your work.http://www.rcuniverse.com/forum/js/f...ular_smile.gif
YHR 08-14-2010 01:35 PM
WOW. I master craftsman of the highest order has arrived. Splendid work, what else can be said. Few reach the level you have just demonstrated in this scratch build.
Thank you for posting on the forum. There are a couple of other guys on here that are marvalous scratchbuilders, and could probably match your level if they applied themselves, but you have really set the bar high .
This is truly inspirational, although I doubt I will ever reach that level of accomplishment. Maybe when I retire, or in my dreams:D
Anyway, a truly great build.
Send that off to Tamiya or Heng Long and tell them to get the die cutting machines warmed up.
Pzjgr 08-14-2010 01:41 PM
That is great work you did. It's beautiful, how long did it take to complete it?
Duane
four slot 08-14-2010 04:17 PM
That's not stratch building thats LUNACY .......... SO I shall go back to my hole and shut up now that's just to nice.
Disposable Hero 08-14-2010 08:52 PM
Good god!.....that is abosolute "rolling artwork".....I'm MEGA-jealous lol....:(
pattoncommander 08-14-2010 08:53 PM
fantastiche..mach schon weiter.[X(]
Very fine workmanship. Next a Centurion, right/:eek:.
yellowshaker 08-14-2010 09:31 PM
Uhhh...hmmmm....Well, not much more I can say. Thank you for humbling me sir! That is one of the most amazing builds I have ever seen on any scale. Marvelous!
