RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
Carb setup
Old 01-17-2011 | 10:42 AM
Default Carb setup
<span style="font-size: large;">Hi guys i have a hot bodies lightning stadium pro with its original engine and carb and like an idiot i tinkered with the 2 screws on the carb and now i cant get it to run right can someone shed some light on this so i can get it setup again. Thanks</span>
Old 01-17-2011 | 03:08 PM
Default RE: Carb setup
If you have the manual it came with look up what the stock settings were on it and start there, only make adjustments in small amounts from there. A little rich is better than to lean. The most popular starting points is 2 and a half turns out on both upper and lower speed adjustments if you cant find your manual.
