Building a 1/10 Electric Truggy from Scratch
Title says it all.
Naturally, the motor, ESC, and other electronics will be store bought, but the chassis, shock towers, etc. will he homemade from aluminum I got sitting around.
I'm just looking for some tips along the build. Anything that can help in any way is appreciated.
Besides the chassis the next easiest thing to make yourself is probably the suspension arms. You can buy delrin in flat stock in the thickness you want. Then you can cut out the shape of the arm with a saw and final shape with a Dremel. If you really want to go nuts you can use the delrin flat stock to make your own bulkheads too. Without machining tools you can't make gears, axles and other stuff but there's plenty of different vehicles out there to rob parts off of.
Should I rig up a belt drive system, just for fun?
