Bigger is better?
FL
Bigger is better?
New to truggies. I own a Jammin crt, was wondering what to do about a motor. What are rules or restrictions on motors? I want to eventually step up to serious racing. What are the different classes and restrictions? Would I limit myself by using a bigger motor, or should I go with one of the competition 21's? I own a Picco 26, would this get me banned from certain classes? Is there a class for truggies only? I know of the one obvious Unlimited monster truck, what are some others?
RE: Bigger is better?
truggys fall under the umt class. the rules are pretty wide open this year. the most restrictive rule is that you have to stay under a .28. that .26 you have would work perfect. in my opinion put a 2 chamber pipe on it with a light clutch and heavy clutch springs would be a sweet setup.
FL
IMHO the clutch you use is as responsible for good accelaration as is the engine / pipe combination.
I would say that with a high torque engine with a heavily engaging clutch with little slippage, a pipe that further increases low end torque will only lead to spinning wheels and no increase in traction. I have heard that the best possible offroad traction occurs when you keep the spinning of the wheels under 20% - that means the wheels should turn no faster than actual car speed plus 20%. After discussing things with friends and drivers in different forums, including this one, I just decided for a JP-2 instead of a JP-1.
Big displacement engines are great have enough low end for (comparatively light weight) truggies and can use a pipe that helps with the mid to hi rpm range. This is especially true for 3 port engines. In a heavy monster truck things look different because you may need all the torque you can get.
FL
Thanx for the informative info Ferdi. So how does this sound? Gold clutch springs to bring the rpm's up a bit before engaging the clutch (sounds like it should help low end, yes no?) and a JP-2 for top end power. The current setup (Mach 28, JP-1, gold springs, 7/10/5) does induce major drift style driving. I get on but I'm not consistent enough to win any races. I'm going to change up diff oils in favor of something lighter in the center and heavier in the front, switch to a JP-2 and let you all know whats up. In the meantime, I sold off my Mach 28 in favor of a more high end motor, I'm going to run a Picco 26 till I get into an RB or Nova 28.
Yes that sounds good to me. There is no track where I live so my experience is not race proven, but I also changed to lighter diff oils center and rear. I used to run 10k, 30k, 3k in my SUT but found it accented the rear axis too much on lose surfaces, it was difficult to control, a little like a 2WD.
Now I switched to Torsen (Fioroni Storm Traction), 10k, grease and am waiting for the &%$(!!! snow to melt to test that setup.
ORIGINAL: 2fast2slow
So how do you think a race prep. Mayhem ST will do with the STS .28, which puts out 3.6hp, and 40,000 rpm
PA
I run a Jammin CRT with a RB Concept, TM928. This engine makes monster tourque on the low end. I use a JP1. The CRT hooks up like no other truck on the market. For racing with the best drivers you need to be able to come off of corners and clear big jumps in a hurry so run that .26 with a JP1. You have to learn when to drive smooth and when to let it rip, thats why the transmitter has a trigger. As for the Mayhem ST, it is a potential race winner but it has a short wheel base so if the track is smooth with mild jumps they are hard to beet but the front tires balloon very badly and that causes the need to run very heavy diff fluid in the center, like 50K. The guys that run fluid this heavy lose the advantage of having a center diff and handling suffers in the rough and in tight bumpy corners. When someone comes out with an extended chassis for the Mayhem ST, get it. The sportwerks .26 engine in this truck will run with anything out there and it is good on fuel mileage and it holds a pretty good tune.
FL
The sportwerks 26 is a stupid fast motor, for like two gallons though. I guess it's worth it for $100, I may get a second one. As far as truck classes, would running a .21 like the P5 have an advantage for fuel economy in a race? I have to gas up my SW 26 twice to every one time the guys with the 21's gas up.
FL
But is there any way to put 23mm wheels on the Mayhem ST
I will suggest moving to Florida to my wife and kids so I can go racing all year.
You don't accidentally need any German teachers over there? I also teach English, Philosophy and drama...
BTW I'd like to change my signature but can't find the way to do it.
FL
You could try teaching people English, how to speak read and write it.. (God I love it here)
We have a different school system, 13 years from primary to A-levels (which you need to begin university studies). Currently it is being reduced to 12 years. Primary is year 1-4 here, secondary 5-13 (then 12). I teach at a secondary grammar school, at the moment year 5, 7, 9, 10 and 12.
As for German... it is far, far easier than Latin, I can assure you.
As for English... my affinity for that language started more than 30 years ago when BFBS broadcasted 'Sesame Street'.
As for philosophy... I am not a studied philosophy teacher, I only took additonal university courses last year which enable me to teach up to year 10. In fact the subject ic called 'practical philosophy'. IMHO philosophy that UNpractical is not worth teaching at school.
From philosophy to something practical... how the &5$&(/!! can I edit my signature?
FL
HAHAHA!!!! You teach where????
