8ight Truggy
#777
QC, CANADA
RE: 8ight Truggy
Hi there, i finally got my truck. Here's a few shots of it.
It got OS 28XZ and Tsais 32 pipe along with Futaba 3PM fasst radio.
#778
FL
RE: 8ight Truggy
Nice 8t.
I was wondering what setup's you guys use when racing your 8t. I'm going to purchase some silicone fluid and some shock oils and I want some ideas of what you guys are running and what works well. I'm thinking of using 7,10,5k for the truck and putting a higher weight oil in the shocks. What yall think?
#779
OH
RE: 8ight Truggy
i run 7,20,5 front to rear and 40wt in the front shocks and 30wt in the rear with 56 shock pistons all the way around but if you see my track and compair it to yours you will have to make adjustments
#783
OH
RE: 8ight Truggy
ORIGINAL: mordraid
dose anyone know a good aftermarket clutch for the 8t
#786
MB, CANADA
RE: 8ight Truggy
ORIGINAL: rebelracer246
what shoes are the best? and what bell would i need a narrow or a standard?
i use my RR bell's...but u could get away with a Ofna 3 hole vented....and for shoes...it Reallly depends on the motor and track conditions...i would honestly call up mitch and inquire to what he thinks.
#794
RE: 8ight Truggy
Do the rado tray stiffners such as the King Headz radio tray stiffner help save the throttle servos? Is there any benefit to using them?
Are there any must have updates/performance parts to the 8ight-T RTR that should be added before racing?
#795
OH
RE: 8ight Truggy
ORIGINAL: aaronmn
#798
FL
RE: 8ight Truggy
yeah the stock ones. I'm just curious on a ball park idea. I've got maybe a gallon on them now. My muggy's just gave out and it's been a gallon as well, but i know the muggy is hard on them.
#799
OH
RE: 8ight Truggy
i know i had less than a gallon on the stock ones and they gave out i put max lifes on there and i am still running them i will check them after ever race day and they still look good
#800
MB, CANADA
RE: 8ight Truggy
the clutch is Worn out when the shoes are down to 23.3mm......as far as life goes....Every driver will be different....ive seen some shoes last Gallons in one set of hands.....yett in another....they are DONE in a matter of tanks....so in the end experimenting is THE only way to 100% figure it out for yourself....and i Highly suggest you do....as the clutch is Top 3 MOST important parts of the whole vehicle.
