RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
Hellfire SS engine
Old 12-10-2006 | 11:02 AM
Default Hellfire SS engine
Can someone please advise. I have just bought the Helfire ss kit. Is the K4.6 Engine different to the K4.6 HO, is there much differnce?
Old 12-10-2006 | 11:04 AM
Default RE: Hellfire SS engine
From what i understand the k4.6 HO has more agressive porting. But for the money you can get better, not sure about shops in the uk but you can find faster for less
Old 12-11-2006 | 07:08 AM
Hi,
I run a Nosram RS28 ( actually the same as the LRPZ28spec2), with a 15thoot clutch bell and it really rocks !
The engine has lots of bottom end and is very reliable. I think I ran now about 3 gallons tru it in my Savage ( on wich I broke about any drive-train parts ) and 2 gallons in the HF. The compression is still very high. I use after-run oil every time. Temp is about 100° C with Model Technics Fuel 30%.
just to give you a idea, it pulls off wheelies with the 15t bell on the grass.
Definitely the best engine I ever owned
Old 12-11-2006 | 05:03 PM
I have the 46 ho and it has alot of power and runs strong all the time starts right up and goes no problems I race it and it holds it own. Depending on your track size though this motor has a good lower and mid range power band and it has a ton of power even if you run it cool. But if you have a very long track and not a ton of money I really would get the sportwerks 26 v2 this motor rocks and has a ton of top end. But all in all it just depends on your track and what you want the truck to do.
Old 05-06-2007 | 11:03 PM
ANY SUGGESTION ON AN O.S ENGINE IN A HELLFIRE SS KIT? I HAVE A O.S. 18 CVRX in a RC10GT ...i would like a FAST ENGINE AND A RELIABLE ON MY NEW HELLFIRE KIT ,ONE TO BEAT IN THE TRACK! REPLY ENGINE SUGGESTION THANKS..
Old 05-06-2007 | 11:09 PM
aer-wubby's Avatar
I'm actually putting in an Axial .28 1S Spec engine with a JP2 pipe. After break-in, I'm going to see if I should gear up. Definitely seems like a great engine for the price (veered away from STS because of the whole gallon break-in).
Old 05-08-2007 | 11:08 PM
LET ME POSTED, I WILL FINISH 2 BUILT MY KIT, IF THE ENGINE IS GOOD LMK, AND WHERE DID YOU GOT AT TOWERHOBBIES.COM?
Old 05-08-2007 | 11:10 PM
ORIGINAL: aer-wubby
The axial engine isn't too different from the stock 4.6 engine, they are made in the same factory lol.
and about the gallon break in, most quality engines take up to or over a gallon
Old 05-08-2007 | 11:14 PM
aer-wubby's Avatar
ORIGINAL: Kemo
ORIGINAL: aer-wubby
The 4.6 doesn't cost 104, though.
I was also told I shouldn't WOT for too long after a gallon goes through the STS.
