Lightning Stadium setup
QC, CANADA
Hello guys,
I'm new to truggys, just sold my Stadium truck. I got a used Lightning Stadium Pro truggy, but some work needs to be done before I can try it!
I'm trying to find a good general setup that I can use as a starting point and then adjust from there. It's pretty hard to find anything useful about this truggy (most setup sheets I've seen mention things like "upper arm position: stock" etc...) Hey I don't know what is the "stock" position!
So could someone post a good basic setup for this truggy?
Also, I don't know if it's because of the setup or a bad part, but when the front shocks are fully extended, there's a fair amount of toe-out even if toe-in is dialed at ride height (bump steer?? ). Any idea how to fix that???
Thank you!
Thank you!
