Thunder Tiger ST-1 Pull Start Problem
I just bought an ST-1 and had some problems starting the engine. After a sore arm, I ended up breaking the pull start on the PRO 28BX. I took the pull start apart and fixed it temporarily. I am trying to get a pull start spare part but cannot find the part number or a store that has it. Any ideas?
Also, any one recommends a starter box instead of the pull start?
Thanks, Antoine
Thanks, Antoine
TX
RE: Thunder Tiger ST-1 Pull Start Problem
Go to www.amainhobbies.com and order the roto start system. It sells for $28. It comes with the back plate and starter drill. Just make sure you warm your engine up with a heat gun or hair dryer before starting. You will strip your one-way bearing or break your pull start with cold engine.
