hellfire breakin
Guys the temperature is finally warm enough to break in hellfire. Any tips or advice would be much appreciated. I am most concerned about where to apply after run oil and how much. Happy Easter.
im not to shure about this after run oil but to break it in just set the hsn and lsn needles to a slightly rich setting and do some slow runs up and down a a street no full throttle until after 1-2 tanks. or you can start it up and just let it sit ideling with a few squirts of gas to clear the crank case of any fuel every now and again.
just remember to get the best performance and engine life go easy for the first mabye 4 tanks.
if you need anymore help just ask
Good Luck.
Good Luck.
Guys I have been told when it is gonna sit after running for a week or 2 to spay some wd-40 in glo plug hole and turn over a couple times. wd-40 has alot of ewater in it would I be better off spraying a little silicone lubricant in it?
You can buy after run oil or you can use marvel mystery oil, or transmission fluid. As far as break in, I'm assuming you have the RTR with the NS4.6. Just follow the instructions and all will be good. I just put a few drops in the carb and give her a few pulls.
WD-40 has water in it????? [:-]
Now that is the most crazy thing I have ever hear of........
Do you know what the WD-40 is???? The "WD" mean water displacement, and the 40 is the number of ingredients. The WD-40 draws water away from the parts. There has always been a big debate on after run oil vs. WD-40, and I think that they are both fine, use what you got.
As far as where to put it in at. People say through the plug hole or through the carb. I do mine through the plug hole
Oh ya,
and for spraying silicone lube in your motor?
I would have to say that is bad, not sure though.
I think that the silicone in yr motor may cause running problems and motor inconsistancies
