Why me?
MS
Why me?
I am sure most on here have either seen or been unlucky enough to be holding the controller while your nitro vehicle goes screaming out of control. I have a matrix arena RTR. I had just upgraded my throttle/brake servo, RX battery pack, and servo saver arm. I was taking it out for a spin when disaster struck. Durning the first 2 minutes of the run all went great. The new servo really helped the throttle response. I was doing some small jumps when the truggy went full throttle and I could not make it stop. It ran wide open across a field, jumped the road, and hit a tree. I sprinted to it, picked it up (throttle still screaming), turned it upside down and it died. First notice was the front left A-arm broken. I took the body off and noticed the carb was off the engine. My first thought was that the radio had messed up but I do have the spektrum so I thougth everything should have been ok. I noticed the screw that held the carb on was gone. I also tested the radio right after the incident and all was working properly. My question is, do you think that the carb came loose, started taking air, which in turn made the truggy take off? I ordered all the parts today to get it fixed. I just hope the engine is not fried and that it does not happen again.
My Feedback: (-1)
RE: Why me?
That engine is most likely gone. It ran lean as hell with that carb off. I bet you that's why it took off. The sleeve in the carb acts as a limiter to how much air enters the engine. Now when that carb popped off, it was like taking the revv limiter off a car, and going full speed. It's going as fast as it ever would.
And that engine sucked in crap. Just get yourself a new engine, and make sure the carb is tight next time
RE: Why me?
the motor would not run if the carb popped off...most likely the carb got twited and stuck wide open...then when the machine crashed the carb popped off...
My Feedback: (-1)
RE: Why me?
Supertib, so engines will run for a short while with the carb off. But he's probably right. It got twisted because of the initial jump, then it hit the tree, knocking out the carb, and sending the retainer flying.
RE: Why me?
ORIGINAL: MBX5T Maniac
RE: Why me?
By any chance did you have to reverse the direction of the new throttle servo when it was installed? If you did, and didn't reprogram the failsafe settings then it may have gone into failsafe for some reason and opened the throttle full instead of closing it.
Ed M.
Ed M.
RE: Why me?
You could picl up an LRP spec 3 for about 150$ and let me tell you they scream. I also have 2 picco p3's that you can get for about 170. Also a great engine. If you are going to race though you should look to spend a little more. They arent always faster just a smoother powerband. If you are really new you might want to look into something from OS engines. I hear they are very easy to tune.
MS
RE: Why me?
ORIGINAL: bentgear
Ed M.
Ed M.
My Feedback: (-1)
RE: Why me?
ORIGINAL: RCaeroguy
Yeah, for about 2 seconds. If the carb comes off, no more fuel.
MS
RE: Why me?
I think the engine is ok. Has good compression but the glow plug is toasted. Hopefully my parts will make it here Friday so I can get it back together. I was hoping to run on Sunday. I tested some things with the radio and it is working properly.
My Feedback: (-1)
RE: Why me?
If I were you, I'd take the entire thing apart, and clean it out. Doesn't take much to ruin those engines, and a piece of dirt, or crap, trapped in there, at the RPM's the engines are moving at, it's bound to screw it up. Better safe than sorry is all I can say
RE: Why me?
i bet u didnt set the EPA, or ur radio doesnt have an EPA, and ur Throttle is soo torque and strong, that cos u havnt set the EPA, the sservo has just ripped the carb right out, has happenede before, ahh well learn from ur mistakes and get a radio with EPA settings
Banned
RE: Why me?
ORIGINAL: harawong
RE: Why me?
ORIGINAL: dittch
the servo pulls from the side, so there is no way it would pull the carb out. To pull it out, you would need to pull it up. I'm sure you could work one loose with a high torque servo though. A well tightened carb won't should stay put regardless of the servo used.
ORIGINAL: harawong
