what offset??
CA
what offset rims should i get for my jammin x1 crt pro.
i talked to the ofna guy and he said that the proline 1/2 offset throws off the suspension setup.
should i go with these?
http://cgi.ebay.com/Ofna-Yellow-Dish...QQcmdZViewItem
PA
a rule of thumb with offsets is that you never want a narrower ( or is that more narrow?) truck is will almost always screw with the suspension: wider however to an extent can give the truck and the driver an advantage
There is virtually no difference between the Proline 1/2 offsets (13mm) and the Ofna 28mm offsets, the ofnas (according to my measurements, measured against zero offset wheels) are 14mm offset which must be doubled (both wheels) to give an "overall" 28mm.
