Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Truggy
 can you spot the problem? plus tuning issues with the LRP. >
RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
Old 10-16-2007 | 03:14 PM
2DMaxLST!!'s Avatar
Default RE: can you spot the problem? plus tuning issues with the LRP.
Short video...
[link="http://lstvideos.com/12062006/triple.wmv"]Video: I could come around the sweeper and clear the triple no problem with a Spec III at 7 gallons. [/link]
Old 10-16-2007 | 03:17 PM
ttoks's Avatar
well da smak theres a bit to think about there about revving it cold, you can think that taking it easy when cold and warming up slowly doesnt damage it, and you can think that the faster it warms up, the faster the pinch is lost from the expanding sleeve, two ways to look at it from two different perspectives, all opinions, i usually try to get my engines to temps as fast as i can without revving them hard so i'm a bit heavy on the throttle, i just don't let it revv up until its warm, and 2D thanks for the advice on the plugs, i was planing on dabling with some 30% next lot of fuel i get so i'll have a look into gettign some LRP 5's.
Old 10-16-2007 | 03:21 PM
2DMaxLST!!'s Avatar
I would run LRP #5 24/7 if they were available here. I've owned 5 LRP Spec III's and I always take the stock plug, the LRP #5 and set it aside while I break them in. I save that one for racing. I'm breaking in LRP Spec III #5 on the stand this evening.
Old 10-16-2007 | 07:42 PM
RCtruckRacer's Avatar
even when the low speed is very close to the limit of being to lean, the idle drops off as if to rich, it will start easily again, but then stall if not given throttle, even with up to a 2 mm idle gap,
Your idle stop is too big, and you are compensating for that by having an overly rich LSN. Its not too hard to get an engine to run backwards - good compression and overly rich settings can cause the engine to fire around the middle/bottom of the stroke and force the piston backwards. Its happened to me before.
Old 10-17-2007 | 04:30 AM
ttoks's Avatar
got it all sorted, changed the plug to an LC3 and that sorted the idling problem, and then it was just a matter of getting it tuned right, run outa daylight once i'd fiddled around with the plugs for a while though so this weekend maybe, gonna have to look into the LRP 5 plugs.
Old 10-17-2007 | 05:50 AM
  #31
i tend to stick with mc coy #8 or 9 work well and last for ages but got given some cheap ones to try called thunder bolt.suppossed to be between a 6-8 put it in my ttr hammer s18(mini mgt) dont know if i just got a good one or not but it seems to be holding up really well. good plug for a .18 running 20%
