RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
question????
Old 01-25-2008, 09:56 AM
twin34
Default question????
how do you install zip ties and fuel line on gas tank lid so its easy to open during pit stops?
Old 01-25-2008, 04:46 PM
azzman
azzman's Avatar
Default RE: question????
Easy...your tank lid should have a small slot in the part that you lift it up from...slide a zip tie through it, up from the bottom. Take another zip tie and cut the whole tail off it so you just have the square end...slide that on you original zip tie from the top all the way down to secure it to the lid...
Then if want to add fuel line slide a piece down the zip tie (cut it to the length you want it first), then cut the tail off another zip tie and slide it down to secure the fuel tubing...then simply trim the tail off the original zip tie and your done.
Let me know if you need a pic...but if you follow the instructions step by step, you should be sweet...
