---OFFICIAL CASTER RACING K8T TRUGGY THREAD---
#576
FL
RE: -OFFICIAL CASTER RACING K8T TRUGGY THREAD-
ORIGINAL: Oasis TR
Is this a problem with the GO motors? A friend just got a .21 and it had a lot of flame outs in the last few race..We were thinking that some new motors seem to do this and as soon as their "seasoned" the flame outs stop..
#577
Any engine running in the "slightly-too-lean" mode will be susceptible to flame outs, and if the piston/sleeve fit is very tight, even more so when running lean. Tuning is a balance and a fine art that only comes with lots of experience.
#578
FL
the problem was my pit guy was doing double duty and the other driver and i both had byron's, his 25% mine 30%, no one knew till it was all over. the motor was about 4 hours rich and the idle was low. it was 50c in the morning then it was 75-80c for the mains, may have had something to do with it too. the motor has never had any issues, i was too busy playing with my new buggy to tune the motor. thats fine, my worst lap in qualifying was better then the anybody elses best that day.
#579
CA
I run Novarossi and RB motors..I dont have flame out problems..but then again I'm use to tuning my motors and I tend to run a bit on the rich side anyways..I do agree on the tuning..I have been running nitros off and on for about 16 years now..i have learned from my past mistakes..Great thing about the Internet is their is so much knowledge at your finger tips, when I started no one wanted to help a new guy out..so it was a learning process..
#580
FL
ORIGINAL: j_blaze
#581
FL
found cause for flameouts, front clutchbell bearing blew up. it spins smooth for a second with some clicking then clicks to a stop. took it off and it fell apart. thought a set could go 2 weekends, nope.
#582
FL
ORIGINAL: j_blaze
#583
FL
ORIGINAL: vnmsgt
75-80c?? Where do you live, In Europe?! I think you forgot we do Farenhiet here in the US! LOL!
ORIGINAL: j_blaze
#584
SC
Does anyone use the go tech 3 port race spec in thier truggy, how do they like it?? I know t doesnt have alot of bottom, so i would use a 007 high torque pipe
#585
FL
ORIGINAL: st1_racer
??? it has a beastly bottom, beastly mid and good top, i run a jp-4. its a great truggy motor with no issues.
#586
FL
Well guys I finally took a dremel to my steering knuckles. I was happy with the way my K8T turned but saw everyone else locally who run the K8T's and Mugens grind there knuckles and say how much better it turns so I decided to give it a try. It worked very well I must say. The car felt like it wanted to rotate more in the turns on power than before. Guess that little bit extra steering does help out. Very easy mod to do.
#588
My Feedback: (20)
TX
Yes he does, it's HoleshotHobbies.com. You can also go to CasterRacingUSA.com. Caster forum is always pretty active with plenty of people that have the K8T.
#591
FL
ORIGINAL: aric38
It might be a dumb question other than the engine and electronics what is the diff between the rtr and the kit
#592
thanks for the info I drive a RC8T now and was looking for a basher but the more I learn about this truggy I may want to try to race it too I know most of my questions probably have been answerd on one of 24 pages of this tread but i don't have a lot of time to search so thanks
#593
FL
ORIGINAL: aric38
#594
Well vnmsgt, Ive read most of the thread and became very fond of the truggy. Ive also been to you're website and the thing looks amazing.
Just one question what oil are you running (shocks, diffs)
#595
FL
ORIGINAL: REVO_RACER
shocks = 60wt front, 45wt rear with 1.3mm pistons.
#596
FL
or you can go with a faster k8t drivers setup and run 10/10/10 with 80 front and 70 rear with 1.4 pistons and blue springs, about 1 second faster than vnmsgt
try casterracingusa.com forums, theres other setups in there. here in fl we run on looser tracks with hard packed underneath, you start off with a blown off track and descent traction but soon are driving on dusty concrete.
#597
CA
ORIGINAL: j_blaze
OH SNAP..[X(]
#598
FL
ORIGINAL: j_blaze
#600
FL
ORIGINAL: spudly123
what aftermarket bodies do people use?
cheers
cheers
