RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
ST1 two speed problem
Old 02-16-2008 | 11:11 AM
Default ST1 two speed problem
I have lost drive on my st1 and I think the two speed is the culprit. You can see the clutch bell and gearbox spin but theres no drive.
It seems to either not engage most of the time or when you do get going and hit a slight bump it dis-engages [].
Can anyone help as I am not sure what's causing it?
Cheers
Old 02-16-2008 | 11:14 AM
ericem's Avatar
Default RE: ST1 two speed problem
There is a one way bearing. Check it! You need to pull the 2 speed. Look at the exploded view, and spray some wd40 onn the one way bearing and clean the shaft.
Old 02-16-2008 | 11:29 AM
Thanks for the quick reply.
I will have a look tonight and let you know
