sway bars?
MI
RE: sway bars?
When going through the corners and the inner tires start to come off the ground the sway bar helps push them down and keep them down. In some cases it limets suspension travel.
SK, BANGLADESH
RE: sway bars?
you know how in a real car, especially like an SUV when you go around a corner the whole car leans over.. swaybars make the car stay more level through the corner, and can also be used to tune the handling balance from under/oversteer
MB, CANADA
RE: sway bars?
ORIGINAL: madmax22
better for ON-ROAD driving. off road will get really bad handling.
MI
RE: sway bars?
ORIGINAL: Coopz
Some ppl remove the front bars to improve slow speed cornering (I think). Heard it works well on the heavy LSP Pro R.
RE: sway bars?
ORIGINAL: INTEGRA
WHAT......U dont even have a Freeking clue what u are talking about. ..why say something u have Zero Knowledge on. ?
ORIGINAL: madmax22
Integra, I know you think youre the be all end all of RC, but before you go accusing people of being clueless why dont you stop the piehole running for a minute and kick the brain into gear?
Madmax is partially right. I would be willing to bet you my next check against yours you wont find a lot of swaybar discussion on the Crawler forum. MT either really. If your racing a buggy or truggy, sure you need them, sometimes.
So, in answer to the OP's question, swaybars are situational. It depends on what youre doing if you need them or not.
RE: sway bars?
ORIGINAL: jay863fl
ORIGINAL: INTEGRA
ORIGINAL: madmax22
then, i dont see you say anything smart yourself. And im starting to doubt you know anything at all
ANYWAYS! back on topic. thanks for the info guys i was just wondering, so it lets the car sway, but not roll?
RE: sway bars?
Basically as you make a turn, the outside wheel gets pushed down, and the inside wants to rise, the swaybar hooks both sides together, so that when the outside pushes down, its also pushing the inside wheel down.
WI
RE: sway bars?
a "sway bar" is actually an anti sway bar and it doesnt just push the wheel thats lifting down. what a sway bar does is it depending on thickness of the bar and how its set up will tie your 2 suspension arms together so they counter act each other if your inside wheel is lifting up the bar will partially pull up on your outside wheel to lower the inside wheel they are not always the best for the front of a big truck on american tracks but they do help out alot on the rear for me it always seems easier to hang the tail out with a sway bar on the back
PA
RE: sway bars?
i took em off i didnt like the way it handled at all[:'(] i guess its just my track its tight and all of the corners are slow.
