Team Losi 8ight rtr Glow Plugs
I just ordered a Team Losi 8ight rtr truggy. I was wondering what type of glow plugs to run in it. I will be running Odonnell 20% in it. I will be runnning it mostly between 70 and 90 degrees. What is the difference between hot and cold plugs. Do you run a hotter plug when it is cold out. thanx
PA
RE: Team Losi 8ight rtr Glow Plugs
Any short hot plug will work. I use a OS 8 the OS % aso works and a bunch others they should have a list of what plugs you can use in the manual.
I ordered the truck and I want to order some spares befoe I get it so I dont have the manual. I like the look of the oddonell plugs does anyone know if theese are any good?
FL
ORIGINAL: ericem
Actually with the mach any long hot plug (for %20 fuel) or any long cold plug (for 30% fuel).
You should be using a long plug, (medium to cold)
manual recomends the dynamite plugs. but any long med plug will do. if you are running 20% I would shy away from the cold plugs. Hot should not be a problem either. the mach engine is really nice and forgiving.
