* . _ - Offical Jammin X2 Thread - _ . *
#301
CO
RE: X2 Build Up W/ Pics, 56K Warning, Complete Build Info W/ Detailed Pics
ORIGINAL: qaiz
Thats great.!
I love the first place trophy tho, a sticker .
My X2's outta comission for about 2 weeks or so [&o].
I like the body you got on in the first pic, what body is that.? Nice paint job...
Thats great.!
sjsschwarz, I use a 7955-tg now and it's been great. I do still have a 1015 for my throttle which is over kill but it work...
#302
I have ACE servos in all my buggys & truggies & MTs & the failure rate is about 10%. Give it another shot.
Regards,
Joe Ling
ORIGINAL: sjschwarz
I broke my ACE 1015 steering servo today. Looks like one of the gears came apart... I have heard about others having problems with this servo too. Anyone suggestions for an alternative with similar or better performance?
Joe Ling
#304
MB, CANADA
I'm looking for info on which King Headz motor mount I need for both the JPX .21 and the .28. Is there one that will fit both? Or do I need to buy both these mounts? or are these only good for the X1?
[link=http://www.amainhobbies.com/product_info.php/products_id/5103]Picco .21 mount[/link]
[link=http://www.amainhobbies.com/product_info.php/products_id/5102]Picco .28 mount[/link]
I'm pretty sure it was mentioned a while back but I can't find it.
~John
~John
#305
CO
I think there only for the X1, the x2 doesn't have the z-brace. I could be wrong though
#306
the x2 just has the straight brace beside the center diff which I suppose is to act much like the z brace lol but no there is no actual z brace on the x2
#307
ON, CANADA
ORIGINAL: xc7
~John
~John
Just buy the Ofna mount, its the only one that works properly ( As of now ). I use it, and I honestely dont know how I went about without it. So easy to pull the engine, 4 3MM screws, and its out, no need to re-set the mesh or anything.
Makes checking the Clutch and bearings SO much easier on race day .!
Heres a few pics
__
ORIGINAL: NewKid
Yep. X2 on that .
#308
The King Headz web site has the next X2 mounts online now. They have two versions, one extended, one not.
Do you guys know if the servo saver on the X2 is adjustable? I keep bending my steering servo horn.
Also, I broke one of my rear lower arms today. The part #s in my X2 catalog pull up X1-CRT parts. Are they the same, i.e., identical?
#309
ON, CANADA
ORIGINAL: sjschwarz
Yep the servo saver is adjustable, theres like a dial you turn. Right hand side of the streeing post, you'll see a spring. Just adjust it. Also, just a tip, Alum servo horn was the end of all my steering issues.
And yep, the X1 arms do fit, and good thing, Hong Nor has made ALL the X1 replacement parts, as stiff as the X2 stock parts ( X2 plastics have more glass in them - Hence stiffer ). So the X1's are identical to the X2 in everyway ( Plastic Parts ) .
#310
Hey guys ,
Im in need of some help please.
I have this 2 peice engine mount http://www.s-m-d.co.uk/image-browser.do?i=2&item=309 .
The problem is i dont have the larger screws or the washers . Could someone please tell me the size of these screws ?
thanks
Pete
#311
Fitted this mount myself yesterday.Bolts are 4mm x 18mm with a split washer used to stop it coming loose.Thread length is 12.5 mm from split washer to end of bolt.
#312
ORIGINAL: bobyracing
Ive ordered them off ebay
Cheers
Pete
#313
CO
Well qaiz I broke down and put the O.S. in and man that thing hauls *****. I qaulified#1 but in the last qualifyer I broke the connecting rod somehow[][]Still love they way this truggy handles and can't wait for my new O.S. .28 to come in lol
#314
ON, CANADA
No pics.!?
That sucks about the Con, sure it was broken in properley.?
I got like 4 gallons or so on mine, and its still running good. And mines been tortured.! Last race like a month or so ago, she peaked at 345F. Left her too lean and forgot to richen her up [&:]. And shes still running fine lol.
Im gonna be switching to a Clockworked JPX .21 soon. Just waiting on the funds to start coming in again, and I should be back in business .
I havent touched my X2 in nearly a month [sm=eek.gif].! Need to break her out and hit the track next weekend.!
#315
CO
My wife lost the camera lol so when we get some $ we need to get a new one. Yes I think it was broke in right ...but not sure i bought it used, so guess i won't be doing that anymore lol. I did order 2 new ones so the break in process all over again. My jammin was running good till last weekend when it developed a air leak though the carb slide, Still have to find and fix that though.
#316
ON, CANADA
Damn, that sucks about the camera. Have lost a few myself and hate it when that happens.!
Lol didnt you atleast run a few tanks threw it Just to make sure. 2 new what, Conrods.? You only need one
As for the JPX, just get some nitro carb sealent ( NOT RTV ) and seal it up
Heres what I use
http://www.amainhobbies.com/product_...ducts_id/17237
Heres what I use
#318
My wheels keep falling off. Any suggestions? I re-tighten the nuts after every heat and before the main. Should I lock tight them?
#319
ON, CANADA
I use these
http://www.amainhobbies.com/product_...oducts_id/4683
Never had a wheel fall off. But a buddy of mine uses locktite. Either way, you'll be fine...
#320
FAST926P FASTRAX 17MM X 1.25 NYLOC WHEEL NUTS - PURPLE (4) I use these fastrax nyloc nuts .Available in blue or purple as i had the the same problem with wheels coming off.Fixed the problem for me.
#321
How often do you guys change your fuel filter?
Also, back to the wheel nuts. I bought the 17mm nyloc nuts from the RC8 and they don't seem to thread onto my X2 axles... Does AE use a different thread than Jammin?
#322
yea threads are often diffrent between companies..I think you just need new nuts as the ones you're using must be stripped unless you're using the wrong tool tighten them...do you have an actual 17mm wrench?
#323
Another trick to use concerning your wheels falling off ,is to take out your hack saw or dremel tool and cut a few grooves in the back of the wheel nut.Helps the nuts dig into the wheel rim stopping them from loosening up.A free fix is allways satisfying tooSure loads of people have had this problem with wheels coming off the x2.
#324
I am having trouble with the servo arm on my steering servo. I am using the Hitec 7995TG servo and a Losi alloy servo arm. The ball end contacts the top of the servo case once the servo is turned a certain distance clockwise, limiting my steering throw in one direction. Has anyone else experienced this? I am thinking of switching to the OFNA alloy servo arm, since it is a little longer than the Losi arm, but not by much.
Another question, do you guys set your steering endopoint with the car sitting on the ground, or with the wheels lifted off the ground?
#325
ORIGINAL: sjschwarz
other than that have fun
