* . _ - Offical Jammin X2 Thread - _ . *
#201
RE: X2 Build Up W/ Pics, 56K Warning, Complete Build Info W/ Detailed Pics
Well, it looks like my chassis is indeed bent. The rearmost part (where the rear skid plate is) is bent upwards a few mm with respect to the wider, center part of the chassis. This must be why I can't get the reconstructed rear chassis brace to go back into place.
I have new plastic braces (thanks benoit) and alloy braces on the way. Do you guys think I can force the chassis back into its normal position using the braces, or do you think I need to buy a replacement?
Also, where are you guys getting your bodies painted, and how much is it costing (US$$)? Also, are you all using X2 bodies, or something aftermarket?
#202
Hi guys,
Just thought I'd show off my BL eletric X2. Had a brief session last weekend & it was way too powerful for me :
Regards,
Joe Ling
Regards,
Joe Ling
#203
CO
ORIGINAL: sjschwarz
#204
ORIGINAL: sjschwarz
that chassis will never be the same again... your going to need to buy a new chassis !
#205
ORIGINAL: supertib
#206
CO
I buy almost all my parts on ebay for cheap!!!!Not sure when you'll be able to get parts besides there
#207
BC, CANADA
I got my x2 chassis of ebay with linkage brace for 41.00 dollars.I`ve seen them go as cheap as 30 and as high as 90,it all just depends on how patient you are or how badly/quickly you need it!Also you can get parts from a-main,chassis from them is just over a hundred bucks,personaly i think your better of with ebay.I was just on ebay and there is some chassis`s coming up, and there are some still at .99 cents!! Good luck!!
#209
MB, CANADA
ORIGINAL: SavageSpawn
How much does the X2 weigh?
#210
joe which neu motor you got on it? i've got another x1 that i might convert to electric..gonna go mm/neu/4s-5s setup.. geared for track running
#211
Do you guys know if the rear drive shaft (center diff to rear diff) from a X1 will fit a X2? I bent mine this afternoon... Thanks!
#213
ORIGINAL: qaiz
Nope, sorry, wont fit. X2's longer...
How'd you bend it.!?
Anyway, track was a mess today and the X2 is super dirty. What do you guys use to clean it up?
#214
ON, CANADA
Simple green and an air compresser. Workes wonders, and a lil' coat of WD 40 after its done.
Gonna clean mine today, will get pics of how it looks once im done .
#215
Thanks quaiz. A few follow-on questions:
(1) do you use simple green in a spray container?
(2) if yes to #1, do I simply spray the simple green on, and then blast it off with my air compressor?
(3) once I spray the WD40 on, do I need to wipe it off, blast it with the air compressor, or what?
Thanks for the help. My X2 looks like a mess and it's upsetting me...
#216
ON, CANADA
Yep, simple green in a spray container, use a lot, dont be cheap .
Just spray it on, let it soak for a few seconds, and then blast it off, and for the hard stuff, let it soak for a lil' longer and you'll be set.
I just use the air compresser to take off the WD 40 once I spray it on. Just wipe the underneath of the chassis with a rag.
And for cleaning the body, soap and water.
And tyres, a nice brush with sturdy bristles, and start scrubbing away.
Lemme know how it goes.
#217
Thanks, this sounds like a great method. I've been wasting my time wiping all the parts with bounty.
#218
ON, CANADA
How long does that take.!?
Wow, dedication at its best.!
I usually do a complete strip down once in two weeks or so...
Just finished doing the shocks, gonna start on the diffs soon...
#220
ON, CANADA
Cant compare it to the 8T, but I recentely built an XT8 for a friend, the X2 feels right on par with that.
Ill try and get a digital scale and will measure up it exactly .
#221
Ok, I'm destroying my X2 part by part....
I have some hub bearings that are shot.
Would these be acceptable replacements: http://www.carolinasrc.com/Webstore/...?idproduct=301
Or would they be lower quality than the stock bearings from the X2 kit?
What bearings would you guys recommend, without going overboard on price?
#222
AZ
ORIGINAL: sjschwarz
http://www.avidrc.com/
#223
ON, CANADA
I cant find the size on their site any where.
The manual says " 8 x 16 x 4 "
On their site, the only size they have is ' 8 x 16 x 5 '
Anyone have any other ideas, I wanna do a complete ceramic bearing upgrade to my X2...
Thanks.
Thanks.
#224
ORIGINAL: qaiz
Thanks.
Thanks.
Anyway, I ordered this ceramic kit from tower: http://www3.towerhobbies.com/cgi-bin...?&I=LXPTD2&P=7
It is for the X1 CRT, but includes all the bearings in my X2 manual. The bearings for the steering ackerman are not listed, but they are shown in the photo, and I believe they are included...
We'll see!
#225
ON, CANADA
Thanks for the link.
Got a set on the way too.
But yeah, probably a typo, Page #29 of the manual..
