battery pack for losi
DE
I was wandering if any one had any suggetsions on a receiver battery pack for my losi 8 truggy.I bought the spectrum DX2 and need a good battery pack to work the receiver in the truck. I want something good but want to spend 30.00 orrunder so what are sopme options???
RE: battery pack for losi
When I had my 8t i used this.
http://www.amainhobbies.com/product_...ducts_id/18753
You will have to dremel out some plastic on the battery box top. This battery held up great running 2 ace 1015's. I made it through 3 heats with no problem. It may have held up for the main but i didn't want to risk it.
How long does a battery pack usually last and can you overcharge them. My manual say's don't charge longer than 12 hours. I forgot it the other night so it charged longer. probably 14 0r 15 hours. Should I replace it? Thanks
LA
ORIGINAL: losi101
No need to dremel, just remove some of the foam padding and it will fit just fine.
LA
ORIGINAL: steve307b
You should be fine.
ORIGINAL: l3asher
ORIGINAL: losi101
ORIGINAL: l3asher
You should be fine.
ORIGINAL: steve307b
You should be fine.
PA
ORIGINAL: steve307b
Thanks, I thought so, but being new to nitro rc I'm probably over thinking things, but loving every minute of it.
ORIGINAL: l3asher
You should be fine.
ORIGINAL: steve307b
You should be fine.
+1 on the stickman pack. very good battery.
I believe every rc hobbiest should have a good peak charger. I bought a mrc 977 a year ago and it's the best money i've spent since the hobby. I can charge any battery I own at any rate from 1amp to 5amp. I can even charge 2 at a time.
With that being said if you invest in a good charger you won't need to buy one for a long time.
ORIGINAL: losi101
