Should i replace?
ON, CANADA
do you guys think i should replace the outer drive in my rear diff? or do you think i can grind out some of the radius and be good for a while?
ON, CANADA
I guess i will. Ill just pick up one set because the others are all fine. I don't want to sink any money into the st1 because i know i will replace it with a kit next year maybe.
ORIGINAL: rageworks
Just swap the left outdrive over to the right and the right one to
the left.
the left.
ON, CANADA
ill have to check my rear bearing to see if its causing extra stress. other than that i dont know what would cause it to wear like that. slack makes sense but the would involve me pinching the cup to reduce it.
