Would This engine work?
TX
I have a Matrix tr area and I was wondering if anyone knew If the ofna jpx .28 engine would fit in it? if not is there some motor mount that would work with it?
Ajk
Ajk
Do you have a rotostart engine in it now?
Yes the JPX will fit. You might need to get a Pro version engine mount or something though if the one you have is higher to accomodate a rotostart engine backplate.
GA
If it's the rtr & you are putting in another pull start engine i think it has spacers between engine & mount. Just use those spacers & you should be good.
