Byron fuel?
Byron fuel?
Hey guys I have about two gallons of 30% losi Nitrotane through my 8t with a 427 engine. At $43.50 a gallon for Nitrotane I was thinking of making the drive to A-maine(2 1/2 hrs)and changing to Byrons Originals 30% for 89.99 a case (4 gallons) quite a savings. I only drive at the local track wich is tight with lots of jumps . And will race this month. Any comments on this fuel. Thanks for any info.
RE: Byron fuel?
The fuel is good. Most will agree with that. Some say you should not change brands once you've run a significant amount through the engine. With that 427, I wouldn't worry about it too much.
FL
RE: Byron fuel?
byron fuel is great,
changing fuel doesn't matter just retune,
I stick with one fuel for consistency of tune and how the fuel is affecting my engine
CA
RE: Byron fuel?
Why do you run 30%..Just wondering is all..I did run Byron's but I went back to O'Donnell's..for me I liked it more, but I only Run 20% because it's cheaper and easier on your motors..I feel that the difference in me winning or losing a race has never been a HP problem, I have not been passed down the straights or pulled in the infield running 20% so my feelings are why spend the extra $$ when lack of HP is not the problem..but Byrons is ok..on the fuel prices where are you going? My local hobby shop sells Byrons 30% for $29..no case discounts but it's still not bad, I get my fuel (20%) for $23 a gallon.
