DX3S
I just got my DX3S and I don't have any CA glue to glue the RPM/Speed sensor decal to the flywheel. Do you only recommend using CA glue or will any glue work?
Thanks in advanced
Thanks in advanced
CA
LOL well for anyone else who is wondering CA glue is the best for this application since it dries clear, another name for CA is "super glue" which you can get just about anywhere for under 5 bucks, so there should be no reason to use anything else, which BTW WILL mess with the sensor readings. Use what is recommended here the RPM sensor is about the fussiest thing I have seen...
