8IGHT T Clutch Help
IL
8IGHT T Clutch Help
How do you remove the screw that hods the clutch bell on? The screw that goes into the shaft. When I try to remove it, the engine turns over.
Thanks!
Thanks!
CA
RE: 8IGHT T Clutch Help
you have to keep the piston from turning over. i believe they have a tool for this. once you get the piston or crankshaft from being able to turn over you'll be able to torque the screw and remove it. remember to put lock-tite on the screw when you put it back in, don't want that coming lose while your driving. good luck.
