8t fuel tank ??
PA
8t fuel tank ??
Just wondering....Is the fuel pickup supposed to b towards the front of the tank. I just got a 8t 1.0 and noticed that it's towards the front. Most of my trucks (monster truck)
have it to the back. Can u guys tell me if its in the right spot. plus it has a gold filter cone on the end of the fuel line that's in the tank as the pickup.
Is all those things ok? Thanks
MB, CANADA
RE: 8t fuel tank ??
ORIGINAL: futureboy1969
the tank has a spot for the clunk .....Look at the tank on the outside and you'll see it.....So in other words No the Clunk is NOT supposed to be at the front of the tank. This will prevent the clunk from moving around in the tank when your on your lid....IF its at the front of the tank there will be no wiggle room in the tubing and the motor will stall due to lack of fuel.
PA
RE: 8t fuel tank ??
ok. but i'm still alittle confused. so should i pull the fuel tube that has the cone filter on it, to the back of the tank? so there is extra line in the tank so
when it flips over the fuel tube can lay on the top of the tank and let it keep sucking fuel to the motor?
MB, CANADA
RE: 8t fuel tank ??
i guess i could have explained it a little better...but yes you want the clunk at the rear of the tank and in the little depression in the tank.
RE: 8t fuel tank ??
