Engine for Meister P47 Thunderbolt
The only problem you will have is similar to a radial. You will be fine but expect smoke when you first start up because every bit of fuel and oil will be in the low cylinder. You might have a plug fowling problem. Just be sure to run the engine dry until it quits after every flight or at least after every day of flying. This might solve the smoke or fouling problem al together.
Barry
Barry
![](/forum/images/badges/trading_plus_member.png)
My Feedback: (16)
ORIGINAL: Thunderbolt47
Would the top cylinder run leaner than the bottom?
My Feedback: (8)
ORIGINAL: jeff naul
gravity!!!!! the fuel will naturally fall to the bottom cylinder. you'll have to run richer to keep the top cylinder fueled which will cause the bottom to be in a rich condition all of the time.
