Sculpting a 1/5 scale WWII British Pilot
That is some serious sculpting talent! I'm assuming that the head cast you made is solid? Did you put it under pressure after pouring it to alleviate air bubbles (only way I know to get a cast like that and retain all those fine details)? Also, I'm really curious as to what resin and silicone brand you are using?
Any chance of a 1/5 german pilot at some point? I have a SisT 190D that is going to be looking for a pilot one of these days.
Chris
Resin is Smooth-On Rotocast and the Silicone is Alumalite #3 Heavy duty mold material.
Sorry for all the questions, I make the small scale jet pilots for JHH and am always looking for ways to cast them better. I'm amazed there were no bubble artifacts whatsoever in your casting with all of that intricate detail. I'm sure the pilot being on the larger size helps the resin flow into those areas easier. Anyways, I greatly appreciate your help.
Chris
Congratulations on the birth , no epidural and no air bubbles better still Great looking kid too
Have you ever heard of glove silicone for making the mould? I thought you might be interested as it's what we now use and it enables you to do ONE part moulds. No flashing, no joins. Undercuts no problem. These are the specs
12 Shore A, high tear strength, silicone rubber providing excellent physical properties for glove and skin moulding applications. Great for moulds with large undercuts, and can produce seamless moulds.
Brilliant stuff and you can slush (rotary, hand or machine) cast for a light hollow casting. just done a quick cast of a head and will put a picture of it half born! Sorry about the picture quality, should be working!
Let me know if you're interested and want any more details.
cheers
Patti
Zero-322 - Set up time for the mold material is around 24 hours give or take a couple. Set up time for the resin is 6 to 10 minutes depending on temp and humidity. My mold material cost around $2 an oz. and the Resin cost is about $125 a gallon.
P4Patti - I knew you would get a kick out of the birth analogy! The glove silicone process looks very promising. How many impressions can you get out of one? The alumalite starts to break down after about 75 casts. And when it goes... it goes!
I will have to give the glove mold a try, now, back to work. Thanks for sharing!
Chris
I don't really know how many casts you'd get out of the flexible mould sorry - I haven't done that sort of quantity from the one. The thing is it's quick and easy to do and you can remould from one of your castings if it does break down. I'm looking forward to seeing your baby painted.
cheers
Patti
Today I finally got to paint on Sailor. I was really excited to see him in something other than monochrome! I first cleaned the resin cast with soap and water to wash away any mold release. This is VERY IMPORTANT so don’t forget to clean your figures before starting to paint or the paint will come off in later stages.
Next I airbrush a very thin layer of light skin tone. This gives a bit of “tooth” to the paint for the next step which is PASTELs! Yep, something I recently discovered. Pastels are actually one of the most lightfast pigments you can get (ever see any faded on the shelves in the store?) since they are almost completely pigment. I take the colors of Pastel I am going to use and rub them on a small piece of sandpaper, which then becomes my pallet. I simply brush on, LIGHTLY, the colors I want, darker to lighter to get the correct shading.
I know I’m doing something right when I start to slightly get a creepy sensation that Sailor could almost talk to me.
One time I had several pilot heads painted and my wife came in to talk to me but said she couldn’t because all of those realistic little heads looking at her was creeping her out. So I now keep several on my desk at all times! (Just kidding honey!)
After the Pastels, I then spray a coat of Dulcoat to protect it.
The eyes and the eyebrows are then painted. The sculpted in “hair” makes this really easy to do. This is where the extra time in sculpting pays off!
bestpilots.typepad.com
I want to sincerely thank everyone on this forum for your kind words, encouragement and inspiration. This really added a level of enjoyment for me on this project and I hope you all enjoyed it as much as I did!
