operational cowl flaps made easy
My Feedback: (221)
RE: operational cowl flaps made easy
ORIGINAL: nine o nine
If you need to show them off on the ground for judging purposes the motor would not be running of course. Same thing for demonstrating retractable gear for the judges. Mitch
Ram,
I still haven't cut out my cowl flaps on my 1/8" thick cowl for my Corsair. Yes I know I went a little overboard on the cowl fiberglass. It weighs 5.5lbs before I cut out the front for the engine. Do you think this method would work on that thick of a cowl flap? Next question what is your address so I can ship it to you and get it back finished. I pay well.
Barry
Corsairkidd
Barry
Corsairkidd
My Feedback: (221)
ORIGINAL: NCIS
Ram,
I still haven't cut out my cowl flaps on my 1/8'' thick cowl for my Corsair. Yes I know I went a little overboard on the cowl fiberglass. It weighs 5.5lbs before I cut out the front for the engine. Do you think this method would work on that thick of a cowl flap? Next question what is your address so I can ship it to you and get it back finished. I pay well.
Barry
Corsairkidd
Ram,
Barry
Corsairkidd
To answer your question, yes, I do think it would work. I'd use the Du-bro #257s on them (larger hinge pin and pivot = slightly wider gap). Then I would taper the back side of the flap where in meets the cowl in the center of each flap. That's the only tight place. The rest of it opens up because of the curve. Did i say that clear enough? Hope so.
I have a smaller 100" Corsair (seems crazy to say that 'smaller' 100") cowl here, that I want to do. I'll post here how it goes.
#31
My Feedback: (221)
Some additional pictures for details.
1 - the 1/32 ply to just one side
2 - the over laps. 3/16 on the glue side, 7/16 on the overlap to adjacent flap (hinge notched to relieve binding)
3 - one flap near the center is overlapped on both sides
4 - the gaps around flaps and cowl when closed
#32
My Feedback: (221)
ORIGINAL: Mustangman40
That's good point nine.. There are options, looking forward to seeing the vid on the finished product..
#34
I haven't seen this thread before and upon inspection, I've got to say RAM' it's a very nice solution.Really great to see new creative ways of cracking the old nut.A fine job!
#35
My Feedback: (73)
Hi Gary, met you at Monster Planes last year. I finally got everything from Dino for my P47 and have the wings framed up. Thanks for posting this, I will be doing mine as well. What are you using to cut the flaps off with. I've been following yours and Wayne's theds closely. I'm planning on bringing it to MP's this year. Thanks John
#37
My Feedback: (221)
ORIGINAL: JSZ
Hi Doug, met you at Monster Planes last year. I finally got everything from Dino for my P47 and have the wings framed up. Thanks for posting this, I will be doing mine as well. What are you using to cut the flaps off with. I've been following yours and Wayne's theds closely. I'm planning on bringing it to MP's this year. Thanks John
As for the flaps, I cut them off, and apart with a Dremel and the thin composite cutting wheel. Works like a charm. Got to have a very steady hand though, and that last little corner at the cowl I do with an Exacto knife, so as not to nick the cowl.
You have the fiberglass fuselage, right? Can't remember. I know you told me.
I'm always here if you need anything.
Cheers,
Gary Prince
[email protected]
#38
My Feedback: (221)
ORIGINAL: JeffH
I would think that slaving them to the gear would be the easiest solution. You need them open for take off, dirty passes, or any other time you are low and slow to keep the engine cool.
I'm adding all the Hysol epoxy last night and today. As soon as that is done, I'm going to hook them up to a spare RX and take that video of them. Stand by.
#42
This is a really nice setup...great work! I have a question. Do you think for a smaller cowl like a .60 or 1.20 size plane that one servo mounted at the base of the firewall would work if you hooked each wire to opposite sides of the servo arm?
#43
My Feedback: (221)
ORIGINAL: tevans55
When I get into it, I'll post in this thread.
Other ideas or methods are welcome as well.
#44
ORIGINAL: ram3500-RCU
You're welcome. If you decide to do it, please post some pictures here for us all.
Gary
ORIGINAL: NCIS
Thanks for the feedback ram.
Gary
Thanks for the education Gary,
#45
My Feedback: (221)
ORIGINAL: NCIS
I'm going to do it and will post pic's while I'm in the process.
Gary
ORIGINAL: NCIS
Gary
#46
My understanding is that once programmed, the Thermacowl will operate without input from the receiver based on the thermocoupler attached to the engine, so an additional channel is not needed for normal operation. If you add it to a mix, or have a separate channel, then it can be operated manually.
#47
My Feedback: (221)
ORIGINAL: saramos
It would be great is this is not the case, but I think it is.
#48
My Feedback: (221)
Here is that video of the cowl flaps that I promised you guys. This is the first time they have actually been cycled. I'm using a servo reverser in this test. I forget which one it is. It was just one I had laying around. I don't use them as a rule anymore because of all the servo mixing capabilities built into our radios. It works fine here though.
Sorry about going inverted. Hope you guys don't get a headache.
www.youtube.com/watch?v=rVJusOgWUB0
#49
