Reload this Page >
CARF-Models P-47 Thunderbolt
Old 09-04-2012, 02:21 PM
  #501
Joe C
My Feedback: (23)
Joe C's Avatar
Default RE: CARF-Models P-47 Thunderbolt
Very nice!!!
Old 09-04-2012, 02:37 PM
  #502
jzuniga
My Feedback: (7)
Beautiful Kasper!
Z
Old 10-07-2012, 10:57 AM
  #503
baron rojo
hi, anyone can help me.
I tryed my P47 whith carf propeller,manual show pitch must be 14", but i tryed it and moki 250cc was a failure, it was stop by ignition system protection, because it was very hot.
I have a friend who tryed at the same weekend and happened the same.
anybody use a 2 blade propeller? if yes , is it 32x16?
Maybe carf manual is wrong ? it must be less pitch ? for example 30x11?
THANKS IN ADVANCE
Old 10-07-2012, 11:35 AM
  #504
TJPro351
My Feedback: (8)
TJPro351's Avatar
I set my solo 4 blade prop to 11 "units" on the hub.
Old 10-07-2012, 11:56 AM
  #505
fifou313
fifou313's Avatar
I have finished My P47.
I have set the prop to 11 "units" on the prop so the result is 30*14 for the prop.
Here a short video of the first engine test with the 30*14 prop:
[youtube]http://www.youtube.com/watch?v=GqU0RDjmOdY&feature=g-upl[/youtube]
and some pics.
I have planned to make the first flight at the end of october.
The only question I have if the elevator compensation with the flaps. If some one can give me some advise I will be very happy.
Best regards.
Fifou
ID:	1809007   Click image for larger version
Old 10-07-2012, 12:21 PM
  #506
baron rojo
Pls, pay atencion on my words, we tryed 2  diferent p47 and we meet the same , motor was stoped by ignition temperature sensor, about overload propeller charge, check carefull and try the motor more than 10 minuts running ground, we meet a sad failure.
Old 10-07-2012, 12:56 PM
  #507
affas
affas's Avatar
10min ground run with bad airflow and cooling will stop any Moki...
Old 10-07-2012, 01:13 PM
  #508
baron rojo
How you know that it has got bad cooling and bad airflow? Moki only work on the air? After my friend and me meet the motor failure , we tryed whithout cow, and happened the same , i calculate the propeller load rate and 30x14 is 25% more than moki manual say. My question is anybody is flying whith carf 4 blades whith 14 pitch ? I am not asking if anybody will try 30x14, thanks
Old 10-08-2012, 11:08 PM
  #509
fifou313
fifou313's Avatar
Does anyone have advice for my question about mixing elevator /flaps?
Thanks a lot for your answer.
Best regards.
Old 10-09-2012, 11:38 AM
  #510
baron rojo
seems that few people have flown it, mix for elevator is = 0%, you dont need , i tryed 3 times before kill motor,
Old 10-10-2012, 05:41 AM
  #511
glazier808
glazier808's Avatar
Baron,
Try this thread
http://www.rcuniverse.com/forum/m_89..._1/key_/tm.htm
Casey
Old 10-25-2012, 02:46 AM
  #512
DENTO
DENTO's Avatar
Hi guys
Can someone give me some advice on gear,I have jettronic valves on my gear every time I turn the trans on the gear try's to cycle into neutral ,I have to switch up and down a couple of times to get the gear in sink any advice would be good
Regards
John
Old 10-25-2012, 05:10 AM
  #513
Prekin
My Feedback: (19)
Prekin's Avatar
Fifou, your Thunderbolt looks very nice. I think, that you chose good painting.
Do you have some more pictures and 3 view colour drawing?
Old 10-25-2012, 12:38 PM
  #514
fifou313
fifou313's Avatar
Hello Prekin.
Thanks you for your message.
I have found pics on internet for the scheme here : [link=http://www.master194.com/maquettes/serge_m/p-47_razorback/index.htm]P-47[/link]
I have used only this pics to make the paint.
After I have made all the nomenclature of the plane and the marking with my plotter.
I can sell you all the rub on decals to paint all the nomenclature on the plane if you want it.
About the cockpit on pictures I have used the balsa dynamic kit.
If you are interested by the nomenclature or by the rub on decal to make the ameican star or the front bird contact me.
Best regards.
Philippe
ID:	1814757   Click image for larger version
ID:	1814758   Click image for larger version
ID:	1814759   Click image for larger version
Old 10-25-2012, 12:58 PM
  #515
Prekin
My Feedback: (19)
Prekin's Avatar
Thank you very much for the link, Philippe.
I´m not building P-47 now, but I still think about it. If I build it, it will be 2m wingspan.
Is it problem for the decals? I think that your one is bigger.
Thank you for your offer.
Old 10-25-2012, 01:43 PM
  #516
SJN
The P-47 Kasper assembled, had its maiden a few days ago:
http://www.youtube.com/watch?v=SOmbM...ature=youtu.be
Old 11-22-2012, 02:00 PM
  #517
wojtek
My Feedback: (73)
wojtek's Avatar
Philippe ,
the Dynamic Balsa cockpit looks very nice ! [8D] I have this and will use several parts from it , .. I opted for most of the parts from www.iflytailies.com/ for my P-47 though . Between the two, i think I will have most of the scale stuff crammed in there ...
I really am getting anxious to finish the P-47. This project has been on my work bench since last year. But with a new baby at home and with the huricane coming through a few weeks ago its been slow. Heres some shorts of my cockpit dash panel so far I figured I'd share here. I have been keeping the rest of my build under the Metalmorphing P-47 thread .
~V~
Old 12-03-2012, 08:55 AM
  #518
affas
affas's Avatar
Hi,
Starting my CARF P47 build now.
Are there any modifications that I have to complete or are the manual good to go??
Old 12-05-2012, 08:18 PM
  #519
wojtek
My Feedback: (73)
wojtek's Avatar
Not really. The manual is very well written. On my kid i did not have to shave/cut/angle the main gear support blocks. The gear fit and lined up perfectly and I juts needed to drill the mounting holes.
The canopy mounting method is the only thing I'd recommend deviating on , but that's to make it a sliding canopy ..
Im surprised more people are not building there :\
~V~
Old 12-05-2012, 08:26 PM
  #520
ram3500-RCU
My Feedback: (221)
ram3500-RCU's Avatar
That instrument panel is very nice. Very fitting for such a nice airplane.
Old 12-05-2012, 08:28 PM
  #521
wojtek
My Feedback: (73)
wojtek's Avatar
Thanks Gary,
I have a few more pics of the cockpit coming along in the Metalmorphing thread
http://www.rcuniverse.com/forum/m_11..._5/key_/tm.htm
~V~
Old 12-05-2012, 08:32 PM
  #522
ram3500-RCU
My Feedback: (221)
I checked it out. Good stuff. This will be another showpiece for sure.
Old 01-06-2013, 07:45 AM
  #523
P47Pilot
There is some really superb work being exhbited here. Thanks guys for great inspiration. My own build is going way too slow, butat least I have it up on its feetnow.
ID:	1837348   Click image for larger version
Old 04-25-2013, 07:39 AM
  #524
wojtek
My Feedback: (73)
wojtek's Avatar
its taking longer than expected .. ( a new baby will do that ) but its close to maiden ... polishing out and some nomenclature ( over 300 pieces of it , lol ) still needed ...
Wojtek
Old 04-25-2013, 08:28 AM
  #525
uncljoe
My Feedback: (8)
uncljoe's Avatar
Voy
That's AWESOME craftsmanship !!!!!!!!! whens the maiden?
Semper Fi
Joe
