Reload this Page >
CARF-Models P-47 Thunderbolt
Old 02-13-2015, 01:30 PM
  #701
Greg Wright
Greg Wright's Avatar
snobird,
That's looking great!! Finally there will be another CARF bubble canopy Jug out there flying.
Hope to run into you at an event sometime.
Old 02-14-2015, 08:59 AM
  #702
Ragz
Ragz's Avatar
Finally got the tail doors to open "scale like" with cylinders... I am pleased with the results.. Installing pull pull cables on the servo for the rudder and the tail wheel was a PITA... but managed to get that done too.
ID:	2072955   Click image for larger version
ID:	2072956   Click image for larger version
ID:	2072957   Click image for larger version
Old 02-14-2015, 10:00 AM
  #703
Greg Wright
That looks much better Ragz..
I know what your talking about with the pull-pull cables. But once done they work just fine.
Old 02-14-2015, 10:05 AM
  #704
Greg Wright
I also will suggest that during your final assembly of the plane. You will want to Tack-Glue the L-bends of the hinge pins to the sides of the fuselage with a dab of silicone. they will vibrate out if you don't. Do the same on the doors for the main gear in the wing also.
You don't want them to fall out in flight.
Old 02-14-2015, 12:55 PM
  #705
snobird
My Feedback: (36)
snobird's Avatar
Thanks Greg, Meat Chopper may be at TopGun this year
Old 02-14-2015, 03:16 PM
  #706
koal
Great job on the tail wheel doors Anurag! I'm doing a Meister P-47 and just completed the doors using air cylinders. I'm not getting them to open as much as you are. I'm going to do them over paying attention to the geometry you have used. Thanks!
Brad
Old 02-14-2015, 03:43 PM
  #707
ram3500-RCU
My Feedback: (221)
ram3500-RCU's Avatar
Just an FYI. The new Moki 257 7cylinder is slightly smaller in diameter than the 250. Might be a better option for this airplane.
Old 02-14-2015, 03:45 PM
  #708
ram3500-RCU
My Feedback: (221)
On the exhaust, I may be building one of these for a customer and if we do, we well certainly develope the stainless steel exhaust for it. It will be easier than the Corsair was.
Old 02-15-2015, 06:53 AM
  #709
Ragz
Ragz's Avatar
Thank you. Interesting info about the moki257. Is it available in the market already?
Old 02-15-2015, 07:14 AM
  #710
ram3500-RCU
My Feedback: (221)
Yes. I have one in the shop. An owner provided it for his Corsair. He bought it from Vogelsang.
Old 02-15-2015, 07:28 AM
  #711
Greg Wright
Gary P,
I have already worked with Dan Galardo from Custom Pipes RC on a set of semi-scale tips for the CARF p-47. If you do a scale set with him that would be great.
ID:	2073356   Click image for larger version
Old 02-15-2015, 07:48 AM
  #712
ram3500-RCU
My Feedback: (221)
[QUOTE=Greg Wright;11983643]Gary P,
I have already worked with Dan Galardo from Custom Pipes RC on a set of none scale tips for the CARF p-47. If you do a scale set with him that would be great.[/QUOTE
Dan showed me what he was doing with you. A good ulturnitve to the other options out there. Hopefully I can work with a 257 which has a different exit arrangement off the collector ring. I don't think that a totally scale look will work though. I fear the butterfly for the waste gate would be too restrictive. Personally, I'd rather see the exhaust coming out the correct location than to see an exact scale dummy waste gate with cheater holes in the cowl for the exhaust. How do you guys feel about that?
Old 02-15-2015, 07:58 AM
  #713
Greg Wright
Gary,
This is why i chose to just have Dan do it this way because, i wasn't sure how the waste gate would work with the exhaust. I do have this hooked up to come out of this location. i just don't have a picture of it fully hooked up. I did use a piece of the heat resistant flex pipe that runs from the collector ring all the way back to these tips on both sides.
Old 02-15-2015, 08:03 AM
  #714
ram3500-RCU
My Feedback: (221)
Originally Posted by Greg Wright
Gary,
This is why i chose to just have dan do it this way because i wasn't sure how the waste gate would work with the exhaust. I do have this hooked up to come out of this location. i just don't have a picture of it fully hooked up. I did use a piece of the heat resistant flex pipe that runs from the collector ring all the way back to these tips on both sides.
Figured you did. Looks solid. Should work just fine. The flex pipe has proved to handle the heat just fine.
Old 02-15-2015, 08:13 AM
  #715
Greg Wright
Yes the flex pipe works just fine. I flew the plane all last season with 2 pieces of the flex pipe that where about 14 inches long hooked up to the exhaust ring. I had Zero issues with it burning thru.
I know Dan sells the flex pipe. But if you want to order it at a little cheaper cost. McMaster Carr sells it in bulk. Usually order some to have incase i have an issue with it.
Old 02-16-2015, 01:47 PM
  #716
Greg Wright
What is your real name? Have i ever met you?
Old 02-16-2015, 01:54 PM
  #717
snobird
My Feedback: (36)
snobird's Avatar
Don't know if we've met , Dave Skillings, Meat Chopper will be back up plane for R Labonte , who you know , I believe..
Old 02-16-2015, 02:08 PM
  #718
Greg Wright
No Dave we haven't met.
I do know Ray.
I hope to meet you at TG if you are attending with Ray.
Old 02-16-2015, 02:51 PM
  #719
ram3500-RCU
My Feedback: (221)
I do know Raymond very well.
I'll look for you as well Greg. :-)
Old 02-16-2015, 03:35 PM
  #720
Greg Wright
It will be nice to meet you to Gary!
Old 02-16-2015, 04:12 PM
  #721
ram3500-RCU
My Feedback: (221)
Looking forward to it. These things are as much about the people as anything else for me. I'm pretty average.
Old 02-17-2015, 02:10 PM
  #722
snobird
My Feedback: (36)
snobird's Avatar
W o w, I better get those tail wheel doors opening more before I show up at T G.
Old 02-17-2015, 02:24 PM
  #723
ram3500-RCU
My Feedback: (221)
Km
They were almost parallel with the ground when open.
Old 02-18-2015, 05:37 AM
  #724
Greg Wright
These are the best pictures i could find of the real plane to show the tail wheel doors..
ID:	2074336   Click image for larger version
ID:	2074370   Click image for larger version
Old 02-18-2015, 12:23 PM
  #725
Growler84
My Feedback: (8)
Growler84's Avatar
A note of caution when your doors are rigged like this, its very easy for your "holder" to kick the doors and break one off when he goes to stand in front of the stab. That was an irritating event...
