Help with NP 800mm F4u corsair motor
CA
First off, a video of the problem in action: HERE
So basically i crashed my foamie on the maiden due to a reversed throttle and the failsafe (humiliating but true)
regardless, the foam is all repared, but now that i have re-attached my servoes and whatnot to my Spektrum Ar6100e, all the stuff works except my motor through the esc does what you see in the video above..
Can anyone tell me what's wrong/ if i broke the motor.. if this is the case please suggest a replacement.
Thanks so much,
sjrand96
btw product link here:http://www.nitroplanes.com/93a292-80...4g-yellow.html
Thanks so much,
sjrand96
CA
RE: Help with NP 800mm F4u corsair motor
aha, well that wasn't quite the issue but you led me to the problem, so thanks! MY cheapo components that come with this plane were at fault. the motor leads broke internally near the connector, and therefore didn't get full connection.. a little soldering should have me back in the air in no time!
Thanks for replying!!!
