Panel lines on fiberglass fuse
i've heard how to make rivets with glue but i dont know how to make recessed panel lines on a fiberglass fuselage. is there any somewhat simple method other then drawing them on?? thanks
Panel lines
Yes there is a simple method. First prime your Fuse and sand it down to reveal and remove imperfections. Next locate each panel line where it is positioned on the Fuse. Purchase some 1/64 chart pack tape or equivalent. The tape and primer will create your recessed panel line. Place the tape where each panel line is to be and spray a few coats of primer over the tape. Remove the tape with a #11 Exacto blade, carefully. What is left is a recessed panel line in the primer. This is exactly what you're looking for. Hope this helps BobH.
My Feedback: (80)
MI
If you can't find chart/graphic tape locally here is a site that has it. http://www.suppliesnet.com/Tapes.htm
OH
Actually, this link takes you to the graphic tape:
http://www.suppliesnet.com/graphic_tapes.htm
