Spitfire Brotherhood (All Spitfires Welcome)
#2253
AB, CANADA
RE: Spitfire Brotherhood (All Spitfires Welcome)
I just could not wait any longer and was itching to hear the Saito 100 with the Keleo exhaust.
Eventhough it was a bit on the cool side today at +2c, it was not too bad.
The first tuning of the Saito FA100 went well and I had no problems getting it to start.
I had purchased it used and it must have had a few flights under it's belt.
Unfortunately I had moved the low idle setting when I installed the engine and
thought it was the screw that held the control arm in place.
That's why I had to start from scratch.
Question I have is cooling.
Is the hole for the rocker covers on the bottom front of the cowl enough,
or should I make a hole in the back underside of the cowling so that the
air can flow through?
Any advise would be much appreciated as
this is my first 4 stroke and closed cowl setup.
Thanks in advance.
Now I am really getting anxious for that maiden.
https://www.youtube.com/watch?v=txo4Mb90jsQ
Andreas
Happy building and flying.
Thanks in advance.
Andreas
#2254
From what I have tried in the past, I have found the following formula for cooling holes. I was told years ago you need a ratio of 1 to 2. So if you have 1 square inch of area for the intake, you need 2 square inches of exit area. Dont know if thats correct but its always worked for me. One thing about glo fuel, seems it runs way cooler than gasoline. As long as you dont get it too lean.
My opinion but open to other pov's
WBG
WBG
#2255
Andreas ,
WBG is right!! I have use that formula for years and it work for me too!!!!! You want as much air going over the engine as you can get. I had the same setup like you have in your H9 Spit, before I had what people call the 2.4 gig brown out. The plane was a total lost and the engine need $180.00 worth of parts to repair. The plane went in nose first in a pile of rocks!!![&o] One thing you need in your flight box is a Flash Point Infrared Temp Gage by Duratrax. This gage have save me a lot of headache on my 90 size nitro helicopters. What I like to do is to tie the plane down and run the engine with the cowling in place for one tank of fuel and take a reading right after the prop stop. I than use that number as a base when I go and fly the model. If the flight temp is higher than the ground temp, that can tell you two things, the engine is running lean in the air and or the engine is not getting enough air to cool it!!! One thing you will love if you run 15% heli-mix, to see the trail of smoke going down the side of the fuse and over the tail as you do a low high speed pass.
I hope this info help and I am sorry I don't have any pictures to show you how I did my cowling!!
Sonny
aka
jet22b
Sonny
aka
jet22b
#2256
Hi Jet 22b
some very interesting documents on the below sites
http://www.spitfireperformance.com/
Comparative Performance of Fighter Aircraft published 1946
By Sqdn. Ldr. T.S. Wade, D.F.C, A.F.C, R.A.F.V.R
This is the first article of a series by former O.C. Flying at the Air Fighter Development Unit in which he will discuss the flying characteristics of modern aircraft.
Comparing Spitfire XIV, Mustang III, Tempest V, Thunderbolt II and Meteor III
in summary
Speed First prize to the Meteor III
Climb First prize to the Spitfire XIV.
Ceiling First prize to the Spitfire XIV.
Range First prize to the Thunderbolt II.
Roll rate First prize will have to be shared by the Spitfire and Tempest, depending on the speed at which the roll is executed.
Acceleration First prize to the Spitfire XIV.
Dives First prize to the Meteor
Turning First prize to the Spitfire XIV.
regards Mark
regards Mark
Spitfire Brotherhood #142. Capstan
#2258
Looks like a spitfire to me good work on it and I dont see any "mistakes" Just call it field repairs and we all know those are just supposed to keep them flying so they can shoot down more 109's lol.
WBG
WBG
#2259
Jaoa68,
I don't see where you made any mistakes!! Now if you can not live with the mistakes, I will be more than happy to take it off of your hands!!! Just kidding!! You are doing a great job and please keep the up dates coming!!
Sonny
aka
jet22b
Sonny
aka
jet22b
#2260
I continue with details and now I think that must make again. Some reason i put marks 2-4" too tail and now it doesnt looks good....
Even I look orginal plane I make that mistakes. Painting must correct about white border lines. Tape which I use make this lines was bad. This is so difficult because like to make good looking all details. I try to remember that planes belongs to sky and it is only one part that small details.
thanks to all about comments.
#2261
The first rule in modeling scale warbirds is, you never finish detailing and changing. You can work on it from now till the end of time and you will always find some detail that just doesnt look correct. Keep up the great work Keep posting pictures. We love pictures
WBG
WBG
#2262
Jao68;
I agree with WBG!!! One of my club member is a scale nut!! Every time I go to his workshop, he will have one of his war bird strip down because he did not like something!!! You are doing a great job and please keep the pictures coming!! Any small mistake do not show up in the air where the Spit belong!!
Sonny
aka
jet22b
Sonny
aka
jet22b
#2263
ORIGINAL: Capstan
Hi Jet 22b
Hi Jet 22b
in summary
regards Mark
regards Mark
Thanks for the links!!! Lots of good info!!! I still think the wings of the Spitfire came from the shape of the Sea Gull. When these bird are in the wind and not flapping, the wings look just like the wings on the spit!!!
Thanks, again for the links!!
Sonny
aka
jet22b
#2264
AB, CANADA
Hi Jaoa68,
keep the updates coming.
The cockpit and instrument panel is stunning.
Andreas
Andreas
#2265
Hi Brothers
Here are a few up date pictures of my TF Spitfire build!!! Just finish putting the glass cloth on the bottom of the wings. Now to let the wings cure over night so I can do the top tomorrow!! What I did on the bottom wings was to lay the cloth in section. First section, I laid the cloth from where the wing join the center section to where the aileron meet the flaps. After that has been resin, I over lay the cloth where I stop before, all the way to the tips. I did both wings that way and then go to the center section. I make sure I over lap the cloth where the wings join the center section.
Will post pictures of the top part of the wings tomorrow after they are done. Look at the fuselage, that will be fun!!!!
Sonny
aka
jet22b
Sonny
aka
jet22b
#2267
Thanks #1 for the kind words!!
Do you or any of the Brothers know if Top Flite ARF Spitfire. ( see link below. )
http://www.top-flite.com/airplanes/topa0708.html
Did they scrape it, or is it coming out soon??
Can not find anymore info on their website.
Thanks, brothers for any info!!
Sonny
aka
jet22b
Sonny
aka
jet22b
#2269
AB, CANADA
Hi Sonny,
looking good sofar. I guess the fuselage is going to be tricky with all the curves and angles.
One never knows what to expect. That's the fun of it.
I had a look on youtube how other modelers fiberglass their planes. Pretty interesting stuff.
I will have to try it on my next project, should it be a kit and not an ARF.
Keep us updated.
Andreas
P.S.
Couldn't find anything new on the "New" Topflite Spit either.
Keep us updated.
Andreas
P.S.
#2270
ORIGINAL: WARBIRDRCER
Jaoa68 and Jet22b,
Your planes are looking great.
I will be back on mine soon, just been busy on a couple of friends RC projects and other non-RC items.
Keep us posted,
Jaoa68 and Jet22b,
Keep us posted,
casey
#2271
Thanks brothers,
Today, I made little bit again. Ailerons and cabin is taped in when I took photos. This are next project. Now it fun do to because It start look likes real plane...
#2273
Jaoa68,
Looking good!!! Your little friend don't look to happy in the cage!!! The Spitfire will be a keeper and please keep the up dates coming. What engine are you putting in the nose??
Sonny
aka
jet22b
Sonny
aka
jet22b
#2274
Our oldest dog is not happy because his knees (both) made operations and he must be no running and jumping. Other two dogs run and play outside and also some big machine took too much attention.
#2275
Hi Brothers,
More up dates on the Spit wings The tops are done!!! I am glad I did add the cloth. Now to let them cure overnight and seal the edges tomorrow. Like I said before, the fuse is going to be fun!!! One good tip if you use Pacer Z-Poxy finishing resin and you want to save your brushers for next time, put the brushers in isopropyl alcohol 91% and leave them in the alcohol over night. The next day just remove them than dry them off and you are ready to use them again!!
Sonny
aka
jet22b
Sonny
aka
jet22b
